Author: Subject: alloy bell housing for pinto
westf27
posted on 8/1/07 at 06:53 PM Reply With Quote
got a chance to use one of these alloy bellhousings on my type nine gearbox.Question is there is no side aperture for clutch actuation.as you can see the starter can be fitted either side,does this mean the side not used is for the clutch arm,or does it go in from the rear ?
[Edited on 8/1/07 by westf27][img]http://locostbuilders.co.uk/upload/a482165-25a4_2[1].jpg[/img]
555
oliwb
posted on 8/1/07 at 06:59 PM Reply With Quote
You need to use a Saab hydraulic clutch I think...the release bearing basically becomes the atuating arm. I'm not 100% clued up on these so I'm sure someone will be along shortly to clear things up.....Oli.
davidwag
posted on 8/1/07 at 07:09 PM Reply With Quote
You can run starter or clutch cable on either side, whatever is convenient.
Just make a bracket to hold the clutch cable bolted to the starter holes
snapper
posted on 8/1/07 at 07:20 PM Reply With Quote
Some of the Pinto ally sumps are handed and have the hole for the clutch cable on a plate to one side, i have also seen the metal back plates extended to cover unwanted starter hole, i would just cut some steel to fit and use the starter motor mounting holes to bolt it on.
What is going to happen to the other one, guess what i want next.
[Edited on 8/1/07 by snapper]
I eat to survive
I drink to forget
ed_crouch
posted on 8/1/07 at 09:12 PM Reply With Quote
You can either use the Saab parts, as long as you have a lathe to make up a new gearbox nose (the shroud around the input shaft), or you can spend 190 quid with Burton power to buy an of the shelf system. Ive got on fitted to a TVR Vixen, and it is very good, but expensive!!
Ed.
[Edited on 8/1/07 by ed_crouch]
posted on 8/1/07 at 09:37 PM Reply With Quote
Just make a bracket as already suggested . Made mine to bolt up to the 3 starter bolts on the O/S , bit fiddly to connect the cable but not too bad .
Deckman001
posted on 8/1/07 at 09:52 PM Reply With Quote
Std type 9 clutch release arm does not fit inside the alloy jobbies, you will have to cut it and make it narrower, that or get the original one for the alloy bellhousing, as for cable adjustment, I just welded up a 'y' ish shaped bracket to use the excisting 3 bolt holes not being used on the 'spare' side, this was slotted to allow the cable adjuster to slide down into and then be tightened
Hope this helps
Jason
posted on 8/1/07 at 11:05 PM Reply With Quote
Note, you can still buy the RS2000 clutch arm from Ford dealers! I got one a while back for about £23 IIRC.
westf27
posted on 8/1/07 at 11:10 PM Reply With Quote
cheers guys as always loads of decent info
555
procomp
posted on 9/1/07 at 08:07 AM Reply With Quote
Hi as said above it is all std ford RS2000. So parts are redilly available just gotta find them.
Just watch for striped threads on the bellhousing although i usually drill them through and nut and bolt except the top two of course .
cheers matt
posted on 9/1/07 at 08:28 AM Reply With Quote
Also watch for cracks in the bellhousings, they are very light castings and consequently quite thin so prone to cracks around the mounting holes. Can be fixed by tigging them up of course.
