Author: Subject: Propshaft protection?
Jonte
posted on 11/1/07 at 02:21 PM Reply With Quote
Anyone here made any propshaft protection thingys (don´t know what to call it ) to prevent the propshaft rotating freely if it get loose. U know if it breaks at either end.
If you have done it, please post a pic
cheers
Click it
macnab
posted on 11/1/07 at 02:30 PM Reply With Quote
In the book it describes a simple diagonal bar to block the shaft. To be honest I thought that was naff.
I'd prefer a piece of 2mm plate welded to either side of the tunnel.
macnab
posted on 11/1/07 at 02:44 PM Reply With Quote
Oh well here is a horrible story, not sure if its true but it was my traffic cop neighbour that told me it.
Apparently there was a smash involving an escort van, one of the older ones with rear wheel drive.
Its nose was smashed in big style in another car and unfortunately the engine was still running and going full throttle. Due to the damage (I think the driver was dead) they could not get the vans engine stopped. What was clear had happened is that the propshaft had snapped at the diff and had broken through the vans rear floor. Now free and flailing about it was battering around inside the back like a propeller.
Here’s the nasty bit…
Apparently there had been 3 workers in the back at the time, now basically blended.
Oh Dear…
[Edited on 11/1/07 by macnab]
dr-fastlane
posted on 11/1/07 at 04:54 PM Reply With Quote
A piece of 2mm steel plate would not do the job. That’s as thick as the floor of the Escort Van Macnab told about.
Two pieces op 5 or 6 mm bar, bend in a U shape welded into the chassis. With the propshaft rotating free inside would be better. Like some american musclecars have. Or weld some more diagonal tubes into the transmission tunnel.
[Edited on 11/1/07 by dr-fastlane]
I have not failed once. I have successfully found ways that will not work!
https://www.motor-forum.nl/threads/hardtail-dragstyle-project.343482/
NS Dev
posted on 11/1/07 at 05:10 PM Reply With Quote
or make the prop so it doesn't break
posted on 11/1/07 at 06:33 PM Reply With Quote
the closer to its axis you constrain it, the less forceful the flailing is. Or as Nat says, get it specced correct and balanced, job done.
DIY Si
posted on 11/1/07 at 06:34 PM Reply With Quote
You could always place two rings of steel in the tunnel if really bothered to restrain the prop. That way it would only move by about an 1" or so.
Sun Tzu, The Art of War
ayoungman
posted on 11/1/07 at 10:15 PM Reply With Quote
Macnab, ever thought of writing childrens bedtime stories ? .........just a thought
"just like that !"
macnab
posted on 11/1/07 at 10:21 PM Reply With Quote
Actually I was looking at doing kids stories.
posted on 12/1/07 at 12:24 AM Reply With Quote
What, like Jackanory?
DarrenW
posted on 12/1/07 at 09:22 AM Reply With Quote
or Macanory
What do production cars do to constrain the prop. There are loads of rear wheel drive cars out there that never have a problem. i had mine made professionally with all new parts so im confident it will be OK (same company that made all of the drivetrain gear for the newest batman car). I guess the risk on our cars is lessened due to the lower mileages etc. I know props are not exactly sexy and therefore considered a necessary evil expense but its just not worth risking it imho.
Nice story about the escort van btw Certainly illustrates the point.
