andyace
| posted on 13/1/07 at 09:50 PM |
Pinto inlet manifold - pipes needed?
ello, just about to order my Pinto manifold from Bogg Bros. I am fitting zx9r carbs on to them (or rather they are!).
I need to let them know if I need a servo output or a water outlet.
As I am not running a servo I guess the servo outlet is a no.
Do I need the water outlet (the one in the middle of the manifold)? Where does it go to ?
Cheers in advance, andy
john_p_b
| posted on 13/1/07 at 10:06 PM |
yes you'll need the water pipe in the middle of the manifold or you'll be forever boiling it up due to poor waterflow.
i do believe it goes straight to the waterpump.
built a car, built a home, had a family. lost the family, lost the home, still got the car.
andyace
| posted on 13/1/07 at 10:09 PM |
This is the outlet that presumably comes out of the cylinder head?
flak monkey
| posted on 13/1/07 at 10:40 PM |
The outlet on the inlet manifold goes to the heater matrix. You dont need one at all. Mines blocked off.
Sera
http://www.motosera.com
andyace
| posted on 13/1/07 at 10:42 PM |
Thats what steve at Bogg bros seemed to imply.
Many thanks.
procomp
| posted on 13/1/07 at 10:50 PM |
Hi seconded you dont kneed it if the rest of the plumbing is correct.
cheers matt
MkIndy7
| posted on 14/1/07 at 12:36 AM |
If it doesn't cost any more you could have it put on and blank it off yourself... just incase you should ever want a heater.
If your not going for mega lightweight (*insert pinto jokes*)
Then you may choose the luxury one day for those chilly summer evenings on the way home!
jacko
| posted on 14/1/07 at 10:16 AM |
hi i put a water pipe on my manifold it stops air getting trapped it the head + i have it piped to the header tank my car dose not over heat have a
look in my photo archives
Jacko
mcerd1
| posted on 14/1/07 at 11:21 AM |
I got them to put the outlet on for my ZX9R carbs
Mines for an injection head:
andyace
| posted on 14/1/07 at 02:25 PM |
oooo shiney. I think I will get them to put it on and blank it off if I dont use it.
I am assuming I can put a piece of pipe on it and block this off. Will this work?
[Edited on 14/1/07 by andyace]
mcerd1
| posted on 15/1/07 at 12:27 PM |
Probibly best to plumb it in (even if you don't have a heater)
but if you did want to blank it a very short bit of hose with a plug in one end and a couple of hose clips should do the trick
