madteg
| posted on 16/1/07 at 01:03 PM |
Is this diff any good
Have picked whole back axle up for fifty quid number on diff is AAA392. Is it lsd does anybody know ?.
mcerd1
| posted on 16/1/07 at 01:08 PM |
http://forum.fordsierraclub.co.uk/viewtopic.php?t=5843&highlight=diffs
If you beleve the tag is acurate then its a 3.92 LSD
is it a 7" or a 7.5" ?
does it have bolt on driveshafts / rear discs ?
[Edited on 16/1/07 by mcerd1]
givemethebighammer
If that number is correct then it is ideal for your Zetec / type 9. It a 3.92 LSD!. Let's hope it's not knackered!
madteg
| posted on 16/1/07 at 01:13 PM |
diff
It has bolt no drive shafts is that good?.
| posted on 16/1/07 at 01:16 PM |
Bolt drive shafts are Lobro's.... I like 'em! Actually what am I saying, the bolts keep on coming undone....
Splined driveshafts are a little harder to fit because you have to swing the upright onto them. Lobro driveshafts you just bolt in place... Not sure
there's any difference re how much power they'll take....
mcerd1
| posted on 16/1/07 at 02:11 PM |
Lobro's (bolt on) are a bit stronger than the tripode (push in type) but a bit heavier
also the lobro type come with rear discs as standard (altough you get adapters for the other ones)
I asume its a 7" diff ? (ie. 2 long bolts through the front instead of 4 short ones screwed into the front)
it sounds like your axle has come form a 2.0 XR4x4 (or a 2.0 with the expencive LSD option)
of course this assumes that the tag on the diff is accurate - but you wont know untill you test the LSD or take the back off the diff
mcerd1
| posted on 16/1/07 at 02:13 PM |
Did you fit the little lock washer things ? (old ones tend to rot away to nothing)
thats the bit with 2 holes in beside part 'G' here:
bob
| posted on 16/1/07 at 09:31 PM |
Try threadlock mine have never come undone.
