| posted on 16/1/07 at 01:55 PM |
removing cortina hub dust caps
dunno whqt they are called - dust caps? - the dome shaped covers that fit in the centre of cortinal hubs presumably to cover the nut holdind the axle
together - how do you get one off without damaging it? (so no mole wrench)
| posted on 16/1/07 at 02:01 PM |
Small pry bar (ie screwdriver) normally does 'em...
ayoungman
| posted on 16/1/07 at 03:10 PM |
Start with the edge of a steel rule first, they are often stuff with a gasket compound too. Then, once it lifted a little, use a nice wide bladed
screw driver. HTH
"just like that !"
| posted on 16/1/07 at 06:55 PM |
Big pair of water pump grips for me as well , also use on oil filter, pushing brake caliper pistons back and loads of other uses.
flak monkey
| posted on 16/1/07 at 07:04 PM |
Just smack a screwdriver in the side of it and lever it off. Save yourself the hassle of trying to get them off without damage (i have never been able
to). They are only abour £1 each and yes ford still keep them.
[Edited on 16/1/07 by flak monkey]
Sera
http://www.motosera.com
