<<  1    2  >>
Author: Subject: Mechanical speedo for type 9 gear box
myeates
posted on 17/1/07 at 07:41 PM Reply With Quote
hi does anyone know if there is a mechanical speedo can be fitted to the type 9 box. the box has an electronic part on it but no wires etc.
just wondering as have come across some and would be cheaper than a anything else
thanks
mark
ch1ll1
posted on 17/1/07 at 07:45 PM Reply With Quote
do you have a pic of the box?
thought they were all cable driven
tegwin
posted on 17/1/07 at 08:09 PM Reply With Quote
Are you sure you are not getting the electronic reverse sensor confused with the mechanical speedo sender?
myeates
posted on 17/1/07 at 08:10 PM Reply With Quote
no on me sorry not till weekend its a little box about 6 inches from prop shaft out put that had two wires coming out was deffinately to speedo
posted on 17/1/07 at 08:14 PM Reply With Quote
Most type 9s had the cable driven speedo . If you are using electric speedo you may be able to use the sensor. If not I'm sure someone would buy it from you,
myeates
posted on 17/1/07 at 08:16 PM Reply With Quote
can the unit on the box be bought as a separate thing. unfortunately the electronic part is knackered would need new one anyway
ch1ll1
posted on 17/1/07 at 08:26 PM Reply With Quote
if your looking at it from the rear of the box what side is the speedo drive?
ch1ll1
if its a speedo drive ( electric) might want to buy it from you
myeates
posted on 17/1/07 at 08:28 PM Reply With Quote
its on the left if you want will take pics at weekend have you got any pics of the mechanical part of it
flak monkey
posted on 17/1/07 at 08:35 PM Reply With Quote
The type 9 had both electric and mechanical senders fitted. Mine had an electric one fitted, which i removed and blanked off the hole.
Why would you want to fit a mechanical speedo? Its easier to calibrate an electronic one...
Sera
http://www.motosera.com
ch1ll1
posted on 17/1/07 at 08:36 PM Reply With Quote
have you got a pic of one?
cheers paul
[Edited on 17/1/07 by ch1ll1]
myeates
posted on 17/1/07 at 08:37 PM Reply With Quote
got hold of full dash for a MGB and the speedo is mechanical its also very cheap like all in for £10 so want to make them fit now where abouts is the mechanical output couldnt find it on mine
jacko
posted on 17/1/07 at 08:39 PM Reply With Quote
the speedo drive is on the right looking from the rear drivers side inthe uk
myeates
posted on 17/1/07 at 08:42 PM Reply With Quote
definately not confusing for the reverse switch and pretty sure its on the left
[Edited on 17/1/07 by myeates]
flak monkey
posted on 17/1/07 at 08:47 PM Reply With Quote
The speedo sender is on the right hand side (drivers side) looking from the back of the box. The reverse switch is also on the right IIRC.
The reverse switch has 2 connectors on it, the speedo sender had a wire coming out of it.
The sender either mechanical or electric, is positioned at the rear of the box (in the tail housing) right at the bottom about halfway down the tail housing.
The reverse switch is at the top of the box right at the back.
Dont have a pic i am afraid.
Sera
jacko
posted on 17/1/07 at 08:58 PM Reply With Quote
MT75 box???
flak monkey
posted on 17/1/07 at 09:00 PM Reply With Quote
Heres a pic of my T9 box overall:
No closeups i am afraid
Sera
myeates
posted on 17/1/07 at 09:25 PM Reply With Quote
yep reverse on right got a picture not clear but the circled item is the sender on left looking from seat no close ups either
this pic was 6 months ago
flak monkey
posted on 17/1/07 at 09:41 PM Reply With Quote
Actually, yes i think you are right the senders are on the passenger side... i think i can just make it out on the pics I have on my PC.
My apologies.
[Edited on 17/1/07 by flak monkey]
Sera
myeates
posted on 17/1/07 at 09:53 PM Reply With Quote
thats ok i thought i was going mad or even more anyway so let me get this right the box should be able to have the cable fitted easily to something that is already there
getting confused now hehe our boxes are the same anyway
flak monkey
posted on 17/1/07 at 09:57 PM Reply With Quote
If its a cable speedo sender it will have basically what looks like a small hole into the box the cable is secured with a circlip into a recess. The electrical senders have it blanked off and 2 wires sticking out instead.
Sera
myeates
posted on 17/1/07 at 10:22 PM Reply With Quote
i will have to have a look as all that is on mine so far is the electrical one that is just filling a hole will it be the same hole used
Dusty
posted on 17/1/07 at 10:32 PM Reply With Quote
It is the same hole, just the other end of it. Hall effect, three wires. I use it to drive a VDO speedo gauge in my car. Works a treat. I had been looking for a replacement box for a few weeks when my local scrappy said he had just got three in. Went down and one had the hall effect sensor on it. Nearly snapped his hand off. But I didn't take a pic of it!
myeates
posted on 17/1/07 at 10:36 PM Reply With Quote
i see that will be why i didnt notice it will i have to mod the box at all to fit a cable
jacko
posted on 18/1/07 at 07:27 PM Reply With Quote
Ih i must have my gear box in up side down then the cable drive is on the right [ drivers side uk ] but there is a cap on the left side opposite the cable drive is this were the electric plug is fitted ? Graham
<<  1    2  >>
