Author: Subject: Pinto Throttle cable routing
peterparsons
posted on 20/1/07 at 06:18 PM Reply With Quote
Has anyone re routed the throttle cable on the Pinto or left it as standard as on the Sierra?
jacko
posted on 20/1/07 at 07:28 PM Reply With Quote
hi i have bike carbs fitted but the route is just the same as a standard sierra ie over the rocker cover and down to the pedal
Jacko
DarrenW
posted on 20/1/07 at 07:29 PM Reply With Quote
I managed to use what i believe is std sierra cable onto a 38DGAS. Its a touch tight but works ok. Using std sierra meant the connection to carb brkt was good. Many people who convert to bike carbs use alternative cables and ive been led to believe they are not hard to make up.
jacko
posted on 20/1/07 at 07:40 PM Reply With Quote
Thats right Darren i used a push bike brake cable
