bricheun
| posted on 22/1/07 at 07:46 AM |
Carbs leaking - parts? ZX6F
Just about to fit the carbs and manifold, when I thought about testing the carbs for leaks first..
Yes it leaks from the T-piece where the petrol goes in the carbs. Does anyone know where a repair kit can be found?
Kawasaki ZX6 Keihin 36mm CVK type.
And is it difficult to take all of it apart..seems quite a daughting task!
Thanks.
Danozeman
| posted on 22/1/07 at 08:00 AM |
Mine leaked when i first connected them up. Once the pressure got up and went away it stopped and hasnt leaked since.
Dan
bricheun
| posted on 22/1/07 at 10:00 AM |
So it is better to run them even if it leaks and hope it will stop leaking later?
I think the carbs have been sitting dry for quite a while and the O rings may have gone hard.
Shandylegs
| posted on 22/1/07 at 10:22 AM |
Just a thought. What pump are you using? Older bike carbs, by default, tend to use a gravity feed and do not like large fuel pressures. I had the same
problem on my CBR1000 carbs and ended up using a bike fuel pump (Carb'd R1) which immediately solved the problem.
bricheun
| posted on 23/1/07 at 04:14 AM |
I used a pump from a CBR600 F3 - eletric pump which stops pumping when it feels pressure. It leaks even when pressure is taken off. Kawasaki dealers
said they have stopped these parts and no longer available.
Could I use some other O rings??...
