trogdor
| posted on 23/1/07 at 10:07 AM |
rubber mount sourcing
hey again,
i am trying to find some rubber engine mounts to use with fitting my engine, however i already have some mounts that require rubber mounts that are
73mm across and 37mm high in a circular shape. these are for the gearbox, they should reduce tramp and hopefully make the gearbox last abit longer! i
think they are ford capri/cortina ones but am not a 100% sure on this, i need 3 for my gearbox and may as well use them for the engine as well but
does anyone know where i can get some from? i have not found anywhere on the web that will sell me any!
many thanks
RazMan
| posted on 23/1/07 at 10:13 AM |
Have a look at the landrover ones - a bit stiffer than Ford so more suited to higher output engines.
Raz
RazMan
| posted on 23/1/07 at 10:37 AM |
Here you go
£5.99 per pair
Link
I used these on my V6 and they seem quite firm enough
[Edited on 23-1-07 by RazMan]
Raz
trogdor
| posted on 23/1/07 at 10:51 AM |
oooh thats great! i had a look at landrover mounts and could only find ones that were rectangular! these should do nicely
cheers
James
| posted on 23/1/07 at 11:05 AM |
I used for my ultra heavy Pinto the same ones that MK use which are Fiesta gearbox mounts I believe.
Two of them plus a Westfield new gearbox mount and it seems to be as solidly mounted as I'd want.
James
- Muhammad Ali
procomp
| posted on 23/1/07 at 01:59 PM |
Hi rally deighn do them in std road or harder competition versions and at 38mm tall or 50 tall.
LINK.
cheers matt
PeterW
| posted on 23/1/07 at 03:03 PM |
Paddock Spares...
The font of all low cost bits for ya locost...
Engine Mounts
Peter
