Author: Subject: exhaust wrap
cadebytiger
posted on 25/1/07 at 10:52 AM Reply With Quote
exhaust wrap
What si the theory on exhaust wrap. mine don't have any and have not had any for a while.
Is it a case of if it ain't broke don't fix it or should i have it?
Bit worrid about the alt. getting hot as it is quite close
Thanks again
Rupert
Agriv8
posted on 25/1/07 at 11:00 AM Reply With Quote
Mine are wrapped to keep under bonnet temps down.
More worried about fuel and air getting warm than the alternator. From my findings Fiberglass is a very good insulator !!
regards
Agriv8
cadebytiger
posted on 25/1/07 at 11:04 AM Reply With Quote
ahhh I see. Warm air and warm fuel are thinner thus less POWER!
Where is the best place to get it from? What is it made from?
Would kevlar strip do the job?
Rupert
posted on 25/1/07 at 11:39 AM Reply With Quote
It's very useful for keeping down underbonnet temperatures, but the original theory behind exhaust wrap is that it keeps the exhaust gasses hotter, and therefore faster which is good for power (i.e. stronger pulses/reflections which make a tuned manifold more effective).
cadebytiger
posted on 25/1/07 at 12:08 PM Reply With Quote
Where is the best place to get it from does anyone know?
Thanks for the help
Rupert
macnab
also good for hiding shoddy welding
so I'm told like
John Bonnett
posted on 25/1/07 at 12:41 PM Reply With Quote
Rally Design keep exhaust wrap, matting, sleeves for cables etc and tie wraps all from stock and prices that you would be hard pressed to beat. (I do't work for them, just a satisfied customer!)
Agriv8
posted on 25/1/07 at 12:58 PM Reply With Quote
Oh its supost to assist in keeping the noise down as well ( cant really tell with the V8 !! )
I have used the Socks as they are easiest to slide out of the way when getting to mannifols bolts. Bougt mine think its by Thermo-tec from one of the kit car shows.
regards
Agriv8
Agriv8
posted on 25/1/07 at 01:00 PM Reply With Quote
Rupert
Also higher tems on your fuel and air is a can be a cause of detination ( pinking ) though you need to be looking at quite high CR engines.
Regards
Agriv8
posted on 25/1/07 at 02:24 PM Reply With Quote
you don't fit t hem to cast iron manifolds.
also the tape can hiold in moisture so help rust mild steel manifold quicker - a myth or has anyone experienced this?
posted on 25/1/07 at 02:28 PM Reply With Quote
I bought some a year back- Merlin were pretty cheap at that stage (same with the metallic glass fibre flexible sheet). Not sure if that holds true now...
procomp
posted on 26/1/07 at 08:59 AM Reply With Quote
Hi it has also in some cases helped the heat backup into the cyl head and cause problems. Mainly on alloy cyl heads though.
cadebytiger
posted on 26/1/07 at 09:40 AM Reply With Quote
lol. this is on a pinto lump. no alu here
