CraigJ
| posted on 27/1/07 at 01:33 PM |
Zetec and type 9
What is needed to make a type 9 gearbox fit to a 2.0 zetec? apart from the clutch bearing from westfield.
cheers
TangoMan
| posted on 27/1/07 at 02:32 PM |
Craig,
If you are fitting a Zetec do a search as there is loads of info on here.
As for your Type9. A flywheel and clutch combination, either 1.8 Zetec (both) and a corresponding bearing, although I can't remember which one.
Or you can have a flywheel redrilled to fit a Pinto clutch and this uses a Pinto bearing.
A 2.0 Zetec Flywheel will fit but is heavier than a 1.8 or 1.6 variant.
A starter from a 1.8 CVH Sierra will be needed for both options.
The Pinto backplate can be modified to fit or you can make a new one from sheet steel.
A Spigot bearing will be needed to fit in the end of the crank although I can't remember the part number.
I found shortening the sump to 6 inches from the mating face (Silvertop) lines it up perfectly with the bottom of the bellhousing.
That's about it from memory on the gearbox mating side.
Summer's here!!!!
CraigJ
| posted on 27/1/07 at 02:44 PM |
thanks bud thats great info.
Danozeman
| posted on 27/1/07 at 02:48 PM |
zetec cat has all the info you require.
1.8 flywheel is lighter than 2 litre, youl need a 1. mondeo clutch kit and capri release brg. (quinten hazel part no cct133 about 11 quid). Then
itl bolt straight up, fit a sierra cvh starter and away u go.
This will help you also.
lsdweb
| posted on 27/1/07 at 04:28 PM |
And a CVH flywheel can be lighter again! You will need a different crank pickup then though. See my photo archive.
Wyn
