Author: Subject: Sourcing zetec engine. What parts?
CraigJ
posted on 28/1/07 at 11:47 AM Reply With Quote
Im going to be powering my locost with a 2.0 zetec but will be taking a trip to the scrappers for it more than likely if i cant get a cheap mondeo. What parts do i need from the car to make the engine run in my locost?
Engine
loom
Intake manifold
ECU
What else??????
posted on 28/1/07 at 12:14 PM Reply With Quote
1.8 flywheel
1.8 water pump. 2.0 spins the wrong way
1.8 sump
Spigot bearing
cvh starter motor
Megajolt
IMHO its easier to put a 1.8 in and upgrade with 2.0 cams
Then assuming your using a type 9 gearbox:
1.6/1.8 clutch cover and plate
Capri release bearing
Good luck!!
CraigJ
posted on 28/1/07 at 12:18 PM Reply With Quote
i mean what parts do i need from the mondeo.
CraigJ
posted on 28/1/07 at 12:20 PM Reply With Quote
come to think of it might it just be easer to use a 1.8 from the mk5 xr3i 130ps would save having to alter every thing on the 2.0
Werner Van Loock
posted on 28/1/07 at 01:50 PM Reply With Quote
Originally posted by coozer
1.8 flywheel
1.8 water pump. 2.0 spins the wrong way (1.8 escort that is, 1.8 mondeo also spins wrong way)
1.8 sump (escort part again)
Spigot bearing
cvh starter motor
Megajolt
Good luck!!
http://www.clubstylus.be
ecosse
posted on 28/1/07 at 05:55 PM Reply With Quote
As stated, it needs the escort pump, but you might also need an aftermarket inlet manifold as the escort one is too high and the mondeo one too ridiculous (might be struggle to get it to fit as well though!)
Alex
