Simon
| posted on 1/2/07 at 11:14 PM |
KKK (03) Turbo oil feed pipe size
Chaps,
Does anyone have an Audi with above turbos.
If so (or if you know), could you give me some idea on the feed pipe size.
Thanks very much!
Simon
FlansS14
| posted on 2/2/07 at 12:35 PM |
What is it for. Im sure i have some pipes from mk k03 when i went to k04
iirc any hydralic pipe making place can match them
Why didn't i just make it simple!
FlansS14
| posted on 2/2/07 at 12:36 PM |
Simon
| posted on 2/2/07 at 08:29 PM |
FlanS
It for Deimos (the car to the left). It has a Rover V8 in it and I'm using a pair of K03's from an S4 to give it a bit of help in its old
age.
I've made up manifolds and exhaust, just need to start working on other essentials such as oil and water feeds/returns.
Found a site shortly after posting:
http://www.b5one.com/howto/k04.html
Lots of pics and blurb. Showed me what I needed mostly. Will try and get to an Audi shop and order bits (assuming prices aren't ridiculous
Simon
Stewie Griffin
| posted on 3/2/07 at 07:44 PM |
i can take some pics and measurements for u tomorrow
If it doesn't exist, create it yourself
Simon
| posted on 3/2/07 at 07:47 PM |
More the merrier - pics that is
Thanks very much, appreciated!
Simon
AlphaX
| posted on 10/2/07 at 06:28 PM |
Simon,
the oil feed pipe is 10mm diameter, inside 8 mm. It connects to the oilfilter/cooler with a M12x1.25 open bolt and with the to the turbo. The oil
return is 16mm diamter (inside) and bolts with two M6 bolts to the underside of the turbo, and on the other end it goes into the carter.
hope this helps you. If u got any other questions, go for it!
Simon
| posted on 11/2/07 at 12:27 AM |
Cheers very much. I'll go and get meself some pipework, connect it up and chuck some petrol in the ports.
Either a mighty bang or it'll work
Thanks again
Simon
AlphaX
| posted on 11/2/07 at 09:25 AM |
Forgot to say, that part of the oil feed (and return as well) is flexible hose. See attached picture, just above the plate.
good luck,
AlphaX
