Author: Subject: Redtop>Omega gearbox again
Russiow
posted on 4/2/07 at 10:34 AM Reply With Quote
Hi Guys,
Can anyone tell me if there is a good reason why I can't use the later pot style flywheel with the RWD Omega gearbox??
It has a concentric realease bearing so may need spacing to work properly.
But otherwise I can't see why not!!
Help
chrsgrain
posted on 4/2/07 at 12:12 PM Reply With Quote
I used the standard red top engine and bolted it to a standard omega 'box - only thing I has to do was get a spacer turned up in ali to bring the relsease bearing forward - I think by 22mm - but don't quote me on that!
Everything looks fine so far.
Chris
MkIndy7
posted on 4/2/07 at 12:41 PM Reply With Quote
You'll also need the bearing that goes in the end of the Crankshaft as well, for some reason the FWD gearboxed engines don't need/have this.
chrsgrain
posted on 4/2/07 at 01:32 PM Reply With Quote
Yep - good point - got mine from Ford, about £3 I think.
Chris
Russiow
posted on 4/2/07 at 03:20 PM Reply With Quote
Cheers guys...
It's looking like it may work then.
Just one more thing, which flywheel and clutch do u run???
Stu16v
posted on 4/2/07 at 09:29 PM Reply With Quote
Originally posted by Russiow
Hi Guys,
Help
Why do you want to use the pot type flywheel?
Russiow
posted on 4/2/07 at 09:32 PM Reply With Quote
Because i have one!!!
What do you suggest??
MkIndy7
posted on 5/2/07 at 05:46 PM Reply With Quote
Am pretty sure the earlier Flywheel is lighter by a considerable amount (something stupid like 2.5kg!) so it would make more sence to use that.
ned
posted on 5/2/07 at 06:58 PM Reply With Quote
my flywheel only weighs 2.5kg
beware, I've got yellow skin
Russiow
posted on 5/2/07 at 08:44 PM Reply With Quote
So if I get an early flywheel and matching clutch that should work with the omega gearbox.
All I will need to do is make up a spacer for the slave.
MkIndy7
posted on 5/2/07 at 08:51 PM Reply With Quote
Can't help you with the RWD conversion cos mines still in a FWD tin-top, just found the weights tho:
7kg for early and 9.5kg for late
Can't remember which flywheel type mine is but its had about 2kg taken off the factory flywheel weight and thats in a 1Tonne tin top so i'd aim to get the lighter one... or even buy a lightned flywheel in the 1st place.
2.5 Kg Ned that should rev rather freely
ned
posted on 5/2/07 at 09:16 PM Reply With Quote
yes it does thanks
http://www.locostbuilders.co.uk/upload/IMG_1707b.jpg
this one is even lighter but sadly not mine, requires custom starter as is smaller diameter ring gear aswell
http://www.locostbuilders.co.uk/upload/IMG_1906b.jpg
