Author: Subject: Cortina Gearboxes
Neville Jones
posted on 6/2/07 at 08:07 PM Reply With Quote
Cortina Gearboxes
Still trying to sort out gears for the racer.
Can Anyone tell me if the 2000e gearbox was fitted to the Mk3,4,5 Cortinas? Or to Capri's?
Nev.
[Edited on 6/2/07 by Neville Jones]
John Bonnett
posted on 6/2/07 at 08:20 PM Reply With Quote
The Cortina 2000E was a Mk2. I hope this gearbox guide will be of help. http://www.zetecinside.com/xr2/gearbox.htm
John
D Beddows
posted on 6/2/07 at 09:22 PM Reply With Quote
No they weren't, if I remember correctly the regulations for the first few seasons specifically banned '2000E' gearboxes (or was it just the alloy bell housings I forget.......) ANYWAY having just re read this years regs you still can't use them as they weren't fitted in 1300cc rear wheel drive escorts either - it's a shame because the ratios are just about ideal (as you've probably worked out )
I believe the regulation was one of the strange ones that were written to supposedly keep costs down but which actualy meant people spend at least twice as much to get the same thing eg paying someone like BGH 3 times the cost of a 2000E 'box to put 2000E ratios in a legal 'box
GazzaP
posted on 6/2/07 at 10:07 PM Reply With Quote
as said above you can only use the escort 4 speed box or the sierra type nine box sorry.
www.gmpmotorsport.co.uk
andrews_45
posted on 6/2/07 at 11:47 PM Reply With Quote
...Or the type 3 rocket, as per the regs
John Bonnett
posted on 7/2/07 at 07:56 AM Reply With Quote
The Rocket is a wonderful box
procomp
Hi one other thing to consider is that with the club changing all the regs for 2008 regarding gearbox ratio's it might be worth hanging on till after the AFD discussions coming up verry soon (cant remember exact date ).
This may stop you buying one box now and then having to find an other one to comply with the 2008 regs. We and other people will certinally be bringing up the subject of where they think they are heading with the change of regs at the AFD discussions.
However for this year 2007 the regs remain the same.
The 2000 E ratios are definatly ruled out in the regs as others have pointed out.
I will U2U a number to you regarding a possible contact for a supply of gearboxes.
cheers matt
D Beddows
posted on 7/2/07 at 08:42 AM Reply With Quote
Yes but there are 'rocket' boxes and rocket boxes......
procomp
posted on 7/2/07 at 09:02 AM Reply With Quote
Hi and that is what has caused all the problems and now means that we have to change the regs to specify a set of ratios for all to use.
Cheers matt
Syd Bridge
posted on 7/2/07 at 09:24 AM Reply With Quote
I'd like to see everyone forced to use a standard 1300 box. I've got four of the bludgers sitting in the shed. They fetch less than £20 on ebay.
Syd.
