martin1973
| posted on 7/2/07 at 06:38 PM |
mundeo zetec?
got a 1.8 silvertop from a 93 mundeo, but bit confused now some people say i've got to change the waterpump, so can i get the waterpump from a
escort zetec.
also have i got to change the flywheel? thought the 1.8 flywheel was the 1 to use?
can someone give me true answer
martin
theconrodkid
| posted on 7/2/07 at 06:41 PM |
you already have an 1800 flywheel,fine.
if you have PAS on the mundano the pump will spin the wrong way so you will need an escort pump and pulley
who cares who wins
pass the pork pies
stevebubs
| posted on 7/2/07 at 06:44 PM |
Is the pulley on the water pump grooved or smooth? If the latter then you'll want to swap it...
martin1973
| posted on 7/2/07 at 06:49 PM |
thank u greatly
martin
Werner Van Loock
| posted on 7/2/07 at 07:59 PM |
Other good bit maybe is that you already have the correct clutchcover and plate (23 spline), this is where the escort zetecs need changes (17 spline),
so if the clutch is in good shape.
Other bad thing though is the sump, you'll need a escort zetec sump or a custom/modified one.
[Edited on 7/2/07 by Werner Van Loock]
http://www.clubstylus.be
