Author: Subject: Pinto Shortened Sump
pajsh
posted on 10/2/07 at 08:34 AM Reply With Quote
Has anyone got Mark Allansons .pdf for his pinto sump mods.
I did have it but can't find it and the original thread link seems to be dead.
Also as my brother is a plumber would a soldered joint be OK for the shortened pick-up pipe rather than brazing?
pajsh
I used to be apathetic but now I just don't care.
flak monkey
posted on 10/2/07 at 09:12 AM Reply With Quote
I did have a copy of marks pdf but buggered if i can find it on my computer
As for the pick up pipe, i silver soldered mine together with some silver solder 'borrowed' from work. Doesnt need as much heat as brazing (~600deg instead of 800+), so is doable with a couple of blowtorches, but better than soft soldering which melts at ~200 deg IIRC depending on the alloy.
Sera
http://www.motosera.com
RichardK
posted on 10/2/07 at 09:27 AM Reply With Quote
Here is the link to a post that has the pdf available HERE
I used this one though HERE
Regards
Rich
[Edited on 10/2/07 by RichardK]
Gallery updated 11/01/2011
pajsh
posted on 10/2/07 at 01:49 PM Reply With Quote
Posted thanks on the wrong link.
Trying to rush to get to watch the rugby
Mark Allanson
posted on 10/2/07 at 09:27 PM Reply With Quote
You only have to ask
