Author: Subject: Red top slow running thingy..
chrsgrain
posted on 15/2/07 at 08:35 PM Reply With Quote
I've got a standard Vx red top, and there's a slow running controller low down on the inlet side - which is all gummed up with crud - its got electrics in it, so I don't want to do my usual cleaning thing (stick it in the dishwasher!), anyone any ideas??
Chris
posted on 15/2/07 at 08:38 PM Reply With Quote
Carb cleaner.
MkIndy7
posted on 15/2/07 at 09:33 PM Reply With Quote
That would be the Fast Idle Valve,
As suggested lots of carb cleaner down the inlets of it and you'll see allsorts of crud come seeping out of it!
Just carry on until it runs clear... its a common fault on them gettin crudded up or failing completely.
(If its the outside its ali bodied so it should scrub up pretty well)
chrsgrain
posted on 15/2/07 at 10:15 PM Reply With Quote
Thats great - thanks guys - off to the motor factors we go!
Chris
the_fbi
posted on 16/2/07 at 01:45 PM Reply With Quote
Vxl call it an ICV, Idle Control Valve.
If it needs a clean you'll get a really lumpy/poor idle. If you idle fine from cold through to hot then its working fine.
tks
posted on 16/2/07 at 05:44 PM Reply With Quote
Smart ass
Tks
