Author: Subject: MT75 Gearbox
Thinking about it
posted on 23/2/07 at 04:34 PM Reply With Quote
MT75 Gearbox
Pros and cons against a type 9.
robertst
posted on 23/2/07 at 04:58 PM Reply With Quote
against:
- fewer supply of MT75s VS type 9 therefore more expensive.
- Heavier and more cumbersome than a type 9
- replacements (Gaskets, etc) are more expensive
For:
- might withstand more powerful engines than type 9 (dont know for sure).
Tom
ibakes
posted on 23/2/07 at 05:01 PM Reply With Quote
different ratios are cheeper for the type 9
iank
posted on 23/2/07 at 05:08 PM Reply With Quote
I believe it can take more power.
in addition to above:
it has an integral bell-housing making it awkward to use with anything except a Ford engine.
Anonymous
posted on 23/2/07 at 05:10 PM Reply With Quote
MT75 Pros:
Stronger than a T9
Supposedly better shift quality
It might come free with your donor!
MT75 Cons
It physicaly larger than a Type 9, a bit of a squeeze in the tunnel of a book chassis but can be done
Integral bellhousing means you are limited to bolting it onto Ford engines unless you make an adapter plate or chop the entire casting apart.
Limited tuning/upgrade options.
big_wasa
posted on 23/2/07 at 05:18 PM Reply With Quote
I thought it was lighter being an alloy case ?
Will handle lots of power and is very easy to move the gear lever.
Price is often the same as a type 9 if not cheaper.
imho
Marlon
posted on 23/2/07 at 05:24 PM Reply With Quote
hi I have used the mt75 in my build for a few reasons, 1 it's what was in my kebab and
2, the first reason below \/
pro's - Dead easy to move the gearstick back so it's not under the dash.
Has an electronic speedo drive as well as cable
can take higher power than a type 9
con's - it's quite a bit wider than a type 9 so tunnel needs to be wide enough??
It's heavier than a type 9
Its not as upgradeable as a type 9
my prop shaft had to be spot on in length as it doesn't have the sliding input on the box like the t9
If your using it on a pinto you'll need a modified clutch release bearing. (not that cheap)
HTH john.
Band Anyone?
Linky to SWMBO 's band
Linky to Brother in laws band
MKoc 1081
