The Doc
| posted on 25/2/07 at 09:59 AM |
Manifold Connections (X Flow)
Twin choke Weber manifold - There is a 'T' Connector in the middle of the manifold. One side goes to the oil separator. Where should the
other side connect to?
bilbo
| posted on 25/2/07 at 10:04 AM |
Possibly to a brake servo?
Build Diary: http://bills-locost.blogspot.com/
Web Site: http://locost.atspace.com
| posted on 25/2/07 at 10:27 AM |
Yep - brake servo.
Presuming that you're not using a brake servo, you can either block the unwanted hole, or get a single pipe fixing (I think Burton Power sell
them). Be aware that the old fixing may snap when trying to extract it (guess how I know) as it's very old aluminium alloy screwed into the ali
manifold. Not too hard to fix if it does - just drill out the core and pick out the remaining threads - but remember that it's a tapered
thread.
| posted on 25/2/07 at 12:43 PM |
Wonder where all the petrol went? If the union breaks when you try to take it out cut througth the remains using a junior hacksaw blade very carefully
and remove in sections . Got mine out that way
