Author: Subject: Supercharger.
Johnmor
posted on 25/2/07 at 11:53 PM Reply With Quote
Supercharger.
I have been looking into squeezing a few more horses out of my Alfa V6 and have looked at a few tuning ideas, including throttle bodies and cams etc.
But i like the Idea of a supercharger. I can grab second hand Merc or Jag supercharger for around £250 and as I only want to run a boost of around 8lbs I think it may be feasable. I have to reduce the compression to around 81/2/ to 1. I think i may have sussed that but not sure about increasing the fuel and measuring the airflow in relation to boost.
I think 8lb boost will give around a 40% increase in power, not too extreme as to damage the engine
Has anyone played around with superchargers and the assosiated kit.
Dont realy want to go as far as intercoolers etc.
Opinions please
RazMan
posted on 26/2/07 at 12:07 AM Reply With Quote
The Rotrex units look like a good starting point but if you want to use s/h oem blowers they might take a bit of figuring out.
personally I love the idea of a blower - I've done the turbocharger route and was left wanting - too much lag and too little power in too little revs. Give me a blower anytime
[Edited on 26-2-07 by RazMan]
Raz
Chippy
posted on 26/2/07 at 12:20 AM Reply With Quote
Hi Raz, surely you mean the Turbo route, if your talking about lag, non with a Supercharger. Ray
thomas4age
posted on 26/2/07 at 07:39 AM Reply With Quote
an Eaton M90 would suit you fine!
just get a decent intercooling set up working and don't go over 7PSI boost (mostly water-air systems on eatons) and get the mapping of the ecu right and you wouldn't even have to lower the compression probably (don't know any spec of the alfa v6)
take in mind Blimble is currently boosting a 10.5:1 compression engine which will work.
no low comp pistons leaves buget enough to get a decent ECU on that engine, which will give you 3 advantages for once the money, high comp can run lower boost for the same output and having a decent ecu to do the thinking
grtz Thomas
If Lucas made guns, Wars wouldn't start either.
RazMan
posted on 26/2/07 at 07:54 AM Reply With Quote
oops - I really must engage brain. Now edited
Raz
bimbleuk
posted on 26/2/07 at 10:06 AM Reply With Quote
I've have to agree on that engine with low boost you want to run an Eaton M90. If you plan your install and get an efficient flow throughout then running 6-7PSI (remember PSI is just a measure of your inlet restriction!) should not require a lower CR. Though how you control spark and fueling will have a big influence.
On a Rotrex you need to run a higher boost as the average over the rev range is lower. So my 10.5:1 CR only becomes a factor near the RPM peak of 8K RPM. I can restrict the inlet of the Rotrex to help solve detonation problems.
bimbleuk
posted on 26/2/07 at 10:09 AM Reply With Quote
Thought I'd add that one of my previous cars had a CR of 11.5:1 with a roots type blower producing 7PSI of boost with no detonation issues. So it can be done with some decent electronics and a big intercooler!
PeterW
posted on 26/2/07 at 12:15 PM Reply With Quote
WARNING...!! Thicko question....
Can you supercharge via individual carbs, like a set of bike carbs, or does it need to be one large carb a la the old A series blowers...?
Or does it really need injection to work properly...?
Pete
Johnmor
posted on 26/2/07 at 12:39 PM Reply With Quote
Thanks for the response. The comp ratio is 10-1. So it may be ok.
I was hoping to use the existing plenum chamber and duct the from the super charger at low boost as you metioned about 7lb.
I would then probably go via megasquirt to control fuel and ignition.
I have seen a few superchargers from mini coopers on Ebay. Quite small but as the mini is a 1600cc would they provide sufficient flow for a 3.0l.?
Having said that they run a higher boost presure.
I had a look at your archive(bimbleuk) very, very smart engine. 300bhp
OOOOOOHHH!
vovole
posted on 26/2/07 at 12:52 PM Reply With Quote
hey maybe this link can help, gives you also some performance maps.
http://www.eatonperformance.com/superchargers/superchargers.html
if money is no object I would go for the roots charger, better efficiency.
Have you ever considered a Nissholm charger?
if it´s been done don´t do it
RazMan
posted on 26/2/07 at 02:19 PM Reply With Quote
There are certainly loads of the ex-Mini blowers coming up on eBay and if they can be made to work it would be a really cheap way to get some useful power.
I was thinking about one of these but I have my doubts that they would give enough air for a 3 litre (or even a 2.5 in my case)
Raz
posted on 26/2/07 at 03:12 PM Reply With Quote
You're going to have to spin the hell out of a Mini (m45) blower to get reasonable boost with a 3 litre engine.... Roots types aren't the most efficient- that will be a lot of heat, particularly if you're not planning on an intercooler.
Personally I'd either reckon on using a bigger blower or use a mini blower and buy an intercooler with the money saved on the 'charger. Otherwise without dropping the CR you'll either be running with seriously retarded timing or on Avgas!!!
bimbleuk
posted on 27/2/07 at 09:51 AM Reply With Quote
I've sold a few superchargers on ebay from Mini units up to a huge Merc AMG Lysholm supercharger. The Merc M62 units are a good all round SC and a bit easier to mount if you get one without the castings.
Johnmor the Alha plenum is a good design. You could leave the throttle body where it is but for maximum efficiency it should be in front of the SC.
PeterW you can use carbs but they have to be pressurized like a Renault 5 turbo carb.
[Edited on 9/3/07 by bimbleuk]
thomas4age
posted on 27/2/07 at 01:53 PM Reply With Quote
easiest way to set up the throttle's is to take out the original alfa throttle plate, and just use the one that's on the M90 you'll buy, if you do offcourse.
M45 woudl work with very low revs, 've seen them used in eaton + turbo set-ups on toyota V6 engines.
grtz Thomas
Simon
posted on 27/2/07 at 08:17 PM Reply With Quote
I'm going to start with 7 or 9psi, then increase to 1 bar, with standard 9.35:1.00 comp ratio.
I do have a rather large intercooler, which is fully ducted in/out.
Simon
bimbleuk
posted on 1/3/07 at 10:40 AM Reply With Quote
One thing to note is roots blowers make boost by compressing the air at the back of the inlet valves ad in the plenum So an intercooler isn't as efficient as say one used with a centrifugal SC or turbo. I don't think there's an intercooler fitted to the Ariel Atom or K20A converted Elise that I've seen.
NS Dev
posted on 1/3/07 at 05:30 PM Reply With Quote
I did some maths on using a mini eaton blower (M45) on a 2.0 16v vauxhall XE engine, and it just won't push enough air. I could get about 6lb above atmospheric at 7000 revs, and that was taking the blower to over 14,000, which is a bit high.
Merc M62 is good though, spot on for a 2.0 and would work on a lightly boosted 3.0.
Johnmor
posted on 1/3/07 at 06:30 PM Reply With Quote
M62
I agree , having looked further into the subject ,I think the M62 may be a good option. It was fitted to mercs C230 etc from around 89-93.
So i may try and aquire one of those.
It has the added advantage of a magnetic drive in the pully (similar to aircon units) so if i keep the compression ration standard i may be able to simpily switch it on and off in the dash board.
A button labeled "Holly Shit" may be appropriate.
sebastiaan
posted on 1/3/07 at 07:46 PM Reply With Quote
If you are going to switch it on and of, make sure your ift a bypass too (else the intake air needs to spin the blower...)
RazMan
posted on 1/3/07 at 08:35 PM Reply With Quote
Magnetic drive? .... hmm interesting. But how can you bypass a blower? Wouldn't that need two air intakes?
Does anyone know how much power the M62 will absorb? *edit* just Googled and its 30bhp .I am thinking about running it from one of my cams (where I took off the water pump) .... or would that be a no no?
[Edited on 1-3-07 by RazMan]
Raz
Johnmor
posted on 9/3/07 at 06:33 PM Reply With Quote
From cams!!
I think thats a deff "no"
You would put a 30hp load through the cam belt.
Result "bang"
plus cams run at half engine speed so not really practical.
Bought the book by Corky Bell
Fantastic book, a bit more study and i think it looks promising.
RazMan
posted on 9/3/07 at 10:50 PM Reply With Quote
I had a feeling that would be the answer Ah well, it looks like I will have to rethink.
Raz
