Author: Subject: fitting a type 9 to a escort xr3i cvh
FastBarney
posted on 26/2/07 at 08:46 PM Reply With Quote
hey
i want to fit a type 9 gearbox to escort xr3i (flywheel with crank position sensor)
I want to use the original flywheel becaus of the crank position sensor
Witch clutch assembly and thrust bearing do i need to use?
cheers
melvin
will121
posted on 27/2/07 at 08:24 PM Reply With Quote
have a look at http://www.sylva.co.uk/technical/cvh.htm thing the best way may be re-drill the existing flywheel and fit the 1800cvh clutch/release bearing
posted on 28/2/07 at 08:49 AM Reply With Quote
You might not need to redrill the flywheel
ISTR that latter Xr3i have a bigger clutch than the XR3 and other CVH engines ---- in which case the Sierra clutch pressure plate may bolt straight on.
If not compare the clutch part numbers with those used on Zetec conversions (the CVH is closely related to the Zetec.)
FastBarney
posted on 28/2/07 at 05:13 PM Reply With Quote
hey
it's the old type of engine (1990)
i think i going to redrill it
Using a old sierra flywheel as a template
cheers melvin
posted on 28/2/07 at 06:03 PM Reply With Quote
Don't forget to fit a spigot bearing!
posted on 28/2/07 at 08:55 PM Reply With Quote
A lot of people do forget it !
posted on 28/2/07 at 08:58 PM Reply With Quote
If you are going to redrill why not use a 190mm clutch as used on the 1300 & some 1600 Sierra and the Xflow -- more than up to the job and has a lot less rotational inertia.
FastBarney
posted on 28/2/07 at 10:55 PM Reply With Quote
i won't forget the spigot bearing
it's already in
cheers
melvin
[Edited on 28/2/07 by FastBarney]
