CraigJ
| posted on 27/2/07 at 08:38 PM |
Yamaha FZR Fazer engine
What year do i need to be looking for im after the 1000cc 150bhp model. I know a few on here have them fitted what year engine do you have?
iceman26
| posted on 27/2/07 at 08:40 PM |
2001 and on
angus.d
| posted on 28/2/07 at 12:39 PM |
Craig
As an ex-biker if I remember correctly the Fazer 1000 engine was a "detuned" version of the R1 engine (to suit the Fazer 1000 bike's
sports tourer role as opposed to R1's all out supersports character), and although I believe the physical differences between the two engines
are not major I don't know exactly what the differences were.
To be sure of 150bhp I would recommend you get the R1 engine. I had previously asked the question what were the differences between the R1 and Fazer
1000 engines and didn't get a definitive reply on this site.
Angus
angus.d
| posted on 1/3/07 at 01:10 PM |
Some more info.......
Spoke to a bike breaker yesterday. They said that the Fazer 1000 uses an R1 engine but detuned by having 'softer' cams.
Angus.
smart51
| posted on 1/3/07 at 01:55 PM |
Here is some interesting reading
http://www.motorbikestoday.com/reviews
/Articles/yam_fazer1000.htm
Basically, The engine gives the same peak torque as an R1 but 1000 RPM lower in the rev range. It has 143 PS instead of 150. It has 37mm carbs
rather than 40mm with a lower compression ratio. The head is aluminium rather than magnesium. The crank is heavier and the clutch lighter.
http://www.motorcycledaily.com/06sept00fazerspecs.html
1st gear is also 4% taller
It doesn't seem like a bad engine. More low down pull than an R1 at the expense of less top end.
