bob
| posted on 1/3/07 at 09:18 PM |
Fireblade carbs other pipes ?
So i have the blade carbs on the zetec manifold from boggs, i know where the fuel goes in so thats not a problem apart from wanting a 10mm reducer to
8mm from carbs to feed pipe.
The other pipes though breather pipes, where should these go ?
I'm guessing airbox when they were on the blade engine, is it ok to just feed them into the backplate of my filter ?
Danozeman
| posted on 1/3/07 at 09:26 PM |
Are they breather pipes or coolant pipes??
Leave them alone. Iv got fuel in to mine the rest have nothing on them.
Dan
givemethebighammer
| posted on 1/3/07 at 10:03 PM |
Same here, just left them open.
shortie
| posted on 1/3/07 at 10:47 PM |
Bob,
Are these the small pipes or the large one?
Small ones just vent to air, large one can go to an oil catch tank or just vent into your filter or put small breather filter on the end.
Rich.
bob
| posted on 1/3/07 at 10:57 PM |
Thanks lads thats one thing less to worry about
shortie
| posted on 2/3/07 at 09:40 AM |
Have you fitted a panel filter yet Bob??
bob
| posted on 2/3/07 at 10:08 AM |
Panel filter is on its way as i type,should be here tomorow.
The base plate is a blank with the filter so i can sort the pipes out nice and neat,so far info tells me the small ones can go to atmosphere and the
big one to my catch tank but i have now seen the big pipe with a small filter on.
