Author: Subject: Silly question...Which HT lead goes where?
tegwin
posted on 6/3/07 at 03:27 PM Reply With Quote
I went to put my new HT leads on and I dont know where they go...
Which hole in the dizzy should go to which plug on the head?
Dunc
mike smith1
posted on 6/3/07 at 03:28 PM Reply With Quote
What engine is it for?
Mike
tegwin
posted on 6/3/07 at 03:30 PM Reply With Quote
That would help wouldnt it...
Its a 1600 Pinto on a distributor and carbs..
mike smith1
posted on 6/3/07 at 03:35 PM Reply With Quote
Yes unfortunatly i cant tell you, are you sure there arent numbers on the distributor for the relative numbers on the leads?
Mike
tegwin
posted on 6/3/07 at 03:37 PM Reply With Quote
I know which socket on the dizzy is #1...but I dont know which plug that corosponds to...
DarrenW
With the crank sprocket lined up to TDC and cam pulley on the mark, the rotor arm should be pointing to cyl 1. After that they go in firing order clockwise (1-3-4-2 isnt it??)
DarrenW
posted on 6/3/07 at 03:38 PM Reply With Quote
Cyl 1 is at timing belt end of engine.
Mr Whippy
I think its 1-3-4-2 on the pinto find one on the distributor by sticking your finger over the spark plug hole of cylinder one and turn it over by hand till you feel the air compress and the cut out on the lower pulley lines up with the timing pointer. Number one will be where the rotor lined up with the lead on the cap. Very simple to do, don’t you have a manual…?
tegwin
posted on 6/3/07 at 03:40 PM Reply With Quote
Chears, will give it a go..
I do have a haynes manual but I will be buggerd if I can find it in the book...
Lets see if it will start for the first time :-s
Dunc
tegwin
posted on 6/3/07 at 04:59 PM Reply With Quote
Bollocks...the battery is totaly buggered...
Will get another one and see if I can get it to start then!...
posted on 6/3/07 at 07:51 PM Reply With Quote
Pinto like all its 4 cylinder Ford ancestors going back to the model T is a 1243 firing order.
Pinto distributors rotate clockwise.
Mark Allanson
posted on 6/3/07 at 08:22 PM Reply With Quote
I set my pinto up as 1-3-4-2, seems to run remarkable well considering
geoff shep
posted on 6/3/07 at 10:58 PM Reply With Quote
1-3-4-2
No 1 socket on the distributor has a dot next to it. No 1 cylinder is at the front/elt end. Its in the Haynes manual, first or second entry in the engine specifications at the front of the engine chapter (in a sierra haynes manual)
