| posted on 22/3/07 at 11:41 AM |
Bolt in heater take out pipes
Hi peeps.
Just sorting out the heater in my car... A Porsche 911 blower, an oil cooler and some ali is coming together nicely...
Only trouble is this- how do I break into the coolant circuit?
I want to try and avoid expensive T-piece silicon hoses- the CBS bolt-in take-off pipes are an idea but has anyone any experience of using them?
Sounds like a recipe for a leak in the coolant system to me but if they've got a proven track record......
RazMan
| posted on 22/3/07 at 01:09 PM |
CBS made me a few of these which might be a better idea ...
Raz
Bluemoon
| posted on 22/3/07 at 01:16 PM |
Or copper plumbing part's soldered together...
You could paint or polish the part once made...
Dan
| posted on 22/3/07 at 01:24 PM |
Yup... great minds think alike
I was exploring the options of getting some ali bits made up....
And I've got to go and measure the pipes I'm using from rad to the thermostat to see if copper will work....
I've found some 35mm equal T-pieces but by the time I've got one of those and some 35mm pipe etc etc... We'll see....
Cheers!
mookaloid
| posted on 22/3/07 at 05:18 PM |
I have no problem with CBS products they are normally ok......but why do you need a heater?
Just extra weight and the heat just blows straight out
