Author: Subject: dohc sump modification
dpavlov
posted on 9/4/07 at 11:26 AM Reply With Quote
Hi ! When shortening the sump on 2.0 DOHC, do you also cut away bottom of bellhousing and if so, how much?
[Edited on 9/4/07 by dpavlov] Rescued attachment Slika136.jpg
SeaBass
posted on 9/4/07 at 11:40 AM Reply With Quote
I know nothing about the DOHC. Wouldn't have though you could take much off the base of that bellhousing before you get to the ring gear on the flywheel???
Mr Whippy
posted on 9/4/07 at 11:59 AM Reply With Quote
leave the bellhousing alone you mad man only teasing
I think you'll find the flywheel lives in there, besides you are really going to weaken the housing doing that.
Better to make a 5mm steel skid plate for under the sump to prevent any damage.
[Edited on 9/4/07 by Mr Whippy]
big_wasa
posted on 9/4/07 at 12:46 PM Reply With Quote
yep
big_wasa
posted on 9/4/07 at 12:47 PM Reply With Quote
p2
big_wasa
posted on 9/4/07 at 12:49 PM Reply With Quote
No point in chopping the sump if the bell-housing is then the lowest point.
edit
Think I took around 20mm off..
[Edited on 9/4/07 by big_wasa]
AlphaX
posted on 9/4/07 at 12:51 PM Reply With Quote
some only take off the botom two holes
dpavlov
posted on 9/4/07 at 04:44 PM Reply With Quote
So it looks like I would just leave it as it is. For couple mm isnt worth bothering.
