Author: Subject: Motronic
andrewturner
posted on 21/4/07 at 06:43 PM Reply With Quote
Motronic
Anyone used a motronic ECU
12a RX-7
posted on 21/4/07 at 07:15 PM Reply With Quote
isn't that just a name for a type of OEM type ECU made by bosch? like L Jetronic etc.
I don't think they are an aftermarket type ECU?
tks
posted on 21/4/07 at 07:19 PM Reply With Quote
yupsz
motronic is the first digital MCU BMW/ Bosch uses/ made...
its a OEM one sow difficult to manipulate.
mega squirt or OMEX /EMERALD etc.. that are the ones you could look at
Tks
Volvorsport
posted on 21/4/07 at 07:28 PM Reply With Quote
mine uses motronic !!!
if your motor had it fitted , no reason not to use it - unless you need to start modifying inlets manifolds and such .
www.dbsmotorsport.co.uk
getting dirty under a bus
