myeates
| posted on 15/5/07 at 09:40 AM |
cooling again sorry (just making sure ive got the right idea)
hi guys i know its been covered before but just checking im sorting the problem out. this is how i have it now
when the engine is running and i put on a few revs the water fills the header tank
its a x-flow 1.3
you can see the header is plumbed into the heater side of things
[Edited on 15/5/07 by myeates]
myeates
is this the right fix
GaryM
| posted on 15/5/07 at 10:30 AM |
Hi
I had a very similar problem which I believe i've solved by reconfiguring my plumbing to look like this.
  Revised xflow plumbing
Obviously, as you can see i'm not running a heater but the solution was to T the header tank into a low pressure section of the coolant flow.
Gary
[Edited on 15/5/07 by GaryM]
nitram38
| posted on 15/5/07 at 11:54 AM |
The bottom header tank hose should tee off the bottom rad hose.
myeates
| posted on 15/5/07 at 12:39 PM |
great so the way im going to sort it out in the second drawing is then one
nitram38
| posted on 15/5/07 at 02:21 PM |
Yes
