Humbug
| posted on 17/5/07 at 05:51 PM |
Quickshift adjustment made
...per Dave Andrews instructions
http://hometown.aol.com/dvandrews/quick.htm
Gap filled out with Araldite Steel. I also used the same to fix the spacing nuts to the underside of the lever base - decided to do that after trying
to trial fit it using the nuts like washers, and they kept falling off in the tunnel.
I've been for a quick couple of miles and it seems to help reduce the throw quite a bit. It feels a little stiffer than before, but not too
much.
I took it out
| posted on 17/5/07 at 05:57 PM |
Did you do the remote mod as well? Well worth the effort if you struggle to reach the gear lever.
flak monkey
| posted on 17/5/07 at 05:59 PM |
Did that quickshift mod, combined with the gear remote design on Dave Jenkins website. Moved my stick back 5", out from under the dash and
shortened the throw a bit.
Sera
http://www.motosera.com
Humbug
| posted on 17/5/07 at 09:09 PM |
I moved the engine back as far as it would go and cut out the cross bar where the tunnel kinks up under the dash - that's where the lever ended
up so I didn't need to move it back any further
