RichyMkIndy
posted on 12/8/03 at 11:10 PM |
Have Europa Conned me into buying Senders?? HELP ! (part 2)
hi from europa i bought a oil temp sensor, pressure transducer(water pressure), fuel level sensor, and the speedo one which ive already been told i
dont need
Which of the above to i need im running an early pinto with an MT75, speedo, rev counter, oil pressure, water temp and fuel guage
THANKS RICH
gjn200
| posted on 13/8/03 at 07:51 AM |
Well oil temp you dont need, Water pressure I've never ever seen ( who cares as long as it stays cool?) What you want is oil pressure ( i think
mechanical is best) and water temp.
<- Me!
greggors84
| posted on 13/8/03 at 11:24 AM |
I think he means he got a oil pressure sensor, water temp and fuel level.
What about the rev counter sender, will the sierra one work?
Chris
The Magnificent 7!
RichyMkIndy
| posted on 13/8/03 at 11:50 AM |
YES SORRY
OIL PRESSURE AND WATER TEMP AND FUEL
zetec
| posted on 14/8/03 at 07:58 AM |
If running all electronic guages you will need a oil presure sender, water temp sender and fuel level sender. The only way to be sure the guages are
correct is to use senders supplied by the guage maker as the two will be matched. The rev counter should be able to take pulses from a dizzy or ECU.
mad-butcher
| posted on 14/8/03 at 06:06 PM |
all my gauges came from demon and are mechanical they all came ith fittings as standard not sure on the speedo question can you calculate the pulses
on the gearbox to match soeedo as someone said they need to be matched and is the standard wiring the same as the speedo
regards
tony
