RichyMkIndy
posted on 14/8/03 at 01:43 PM |
Does my MT75 gear box have Electronic OUTPUT for Speedo ? HELP !
hello, i have bought an electronic telemetrix speedo and wanted to wire it up to my MT75 gear box, is the output on the MT75 mechanical, hence
i will need to buy an extra electronic sender, OR is it electronic and therefore i can just run a wire straight from the speedo to my gear box??
THANKS RICH
zetec
| posted on 14/8/03 at 03:54 PM |
If the donor car had EFI or ABS then you will have a electronic output for sure. My MT75 had a standard mechanical drive on the offside and three
wires directly opposite on the near side which connect to the electronic sensor, both just in front of the output shaft. 1 for +ve, 1 for -ve and one
for output pulses.
RichyMkIndy
| posted on 14/8/03 at 05:10 PM |
yeah the car has the twim cam 2.0 not pinto and has ABS and EFI(i think) its a K reg saphire. cool so the MT75 has the facilty for both mechanical and
digital speedo's ??
THanks for the help ill send the sender i bought back to the shop
Rich
zetec
| posted on 14/8/03 at 06:14 PM |
I suspect they fitted both as some cars were non ABS and running carbs so only needed mech speedo, also fitted to transits granada etc.
