Author: Subject: megajolt edis,
thesnake505
posted on 25/6/07 at 06:12 PM Reply With Quote
megajolt edis,
ok im gona start parts searching for the stuff i need for edis, gona order the megajolt lite jnr on firday, but was going to scrap yard tomoro to get the triger wheel, the edis, coild pack, pick up sensor and wiring! the question is what engine can i take the trigger wheel from, iv been told a 1.8 cvh but is there any other options? the engine its all going on is a 1.6 pinto with bike carbs
cheers your local friendly snake
RichardK
posted on 25/6/07 at 06:39 PM Reply With Quote
Get as much of the shielded wire from the crank position sensor ( I got mine from a H reg fiesta) will take a while to cut it out but well worth the effort same goes for all the wiring from the edis, the edis plug, wiring to the coil pack, I got some hvt leads off an Escort that were perfect for the spark plugs and new coilpack.
have pictures in my gallery if you want to see how I mounted my cvh trigger wheel.
Good hunting! BTW I paid £17 for everything!
Regards
Rich
Gallery updated 11/01/2011
RichardK
posted on 25/6/07 at 06:40 PM Reply With Quote
Take something to kneel on, you're gonna get messy getting that crank sensor out in this weather!
MkIndy7
posted on 25/6/07 at 06:53 PM Reply With Quote
If you can find a 1.8 CVH Sierra!
We were looking in the Leeds area last weekend and there weren't any! we know most of the best scrapyards etc and they either didn't have a single one or were closed sundays (They must be making 2 much money now!).
Good luck, but if you fail to find one you can still buy a similar one from Ford Dealers (Part No 1078767)
Its a little bigger in diameter (I beleive it goes inside the engine block on the Twin cam or possibly on the crank pulley) this was about £15 and available on next day delivery.
big_wasa
posted on 25/6/07 at 06:55 PM Reply With Quote
Get the Cranks sensor from a Fiesta (Not Zetec ) and its a two min job, But you will need a Torx bit to take it out.
From a Mondeo or the likes it will take ages and its not a nice job.
The trigger wheel on the 1.8 cvh sierra is a big chunk of steel.
Out of interest what engine is it for ?
thesnake505
posted on 25/6/07 at 06:57 PM Reply With Quote
hay i did say but its going on a pinto 1.6 cheers
MkIndy7
posted on 25/6/07 at 06:59 PM Reply With Quote
The pulley is, the trigger wheel can be taken off the back of it and is much nicer than the one i've mentioned above.
big_wasa
posted on 25/6/07 at 07:12 PM Reply With Quote
So you did
You learn something new every day ive had a few but never taken them of
Will have a look next time
thesnake505
posted on 25/6/07 at 07:28 PM Reply With Quote
if a 1.8 seirra is unfindable, what engined fiesta am i looking for, or for that matter what other engined fords will have one, ie esscot 1.8 cvh????
posted on 25/6/07 at 08:01 PM Reply With Quote
You may find this page useful...
LINKY
DarrenW
posted on 26/6/07 at 07:59 AM Reply With Quote
i went the easy route.
MJLJ came with plugs and wiring loom.
VR sensor off a zetec - clean to get off.
Edis 4 was built into MJLJ.
Coil pack and leads off here - again didnt get dirty.
trigger wheel off triggerwheels.com - Quality item.
Whole lot was probs less that £140.
