Author: Subject: Which Radiator 2.0 Pinto
VinceGledhill
posted on 17/9/03 at 02:56 PM Reply With Quote
I have a 2.0 Pinto in my donor sierra and it is clear that the radiator is miles too big.
Please could someone sugest a good one to look out for in the scrap yard?
It seems fairly obvious to me that overheating could be a problem with a big engine (2.0 or more) in such a small car with not much space for a radiator.
Regards
Vince Gledhill
Time Served Auto Electrician
Lucas Leeds 1979-1983
Simon
posted on 17/9/03 at 03:22 PM Reply With Quote
Vince,
I'm using a Polo rad in my car (V8). As yet untested, but works ok apparently. Do a search on here and find a link to the Westfield forum.
It's what was recommended there, and having watched 5 episodes of "A Race Car is Born" with Mark Evans last night, spotted his rad is identical to mine (including the sly use of the Sierra fan switch fitted into the polo rad!!)
Evans was using a 1.8 Zetec IIRC
Simon
zetec
posted on 17/9/03 at 04:20 PM Reply With Quote
Polo 1.0 1983-85 bought from Serck Intertruck part SER2719517 £40 brand new, should be able to handle Pinto easy (fitted to 200+ BHP cars) with 9-10" fan. Serck Intertruck have branches all over so have a look in Yell pages. Fits inside MK nose...Just.
posted on 17/9/03 at 05:17 PM Reply With Quote
Just had a look in your photos zetec, it looks pretty cool. Do they supply the hoses u used as well?
zetec
posted on 17/9/03 at 06:12 PM Reply With Quote
No, mixture of Samco flex and angled hoses, 3/4" standard heater hose and 35/22/15mm copper plumbing tube. Best bet with Samco stuff is to have a ring round for best prices, other stuff just down your local High St.
Mark Allanson
posted on 17/9/03 at 06:18 PM Reply With Quote
I have a K10 micra rad fitted to mine - it looks awful small, but everyone here seems to swaer by them. A mate in the rad trade says he will make me a multiple core one if it overheats - Bloody ideal!
macspeedy
posted on 17/9/03 at 09:06 PM Reply With Quote
I went to rad maker/stockist very helpful found that a capri 2 litre rad was spot on mounted at a slight angle fitted perfect in the Mk nose cone can get u dimensions if necessary the rad was made originaly for pinto so is easily up to the job cost 65 ish with the filler removed i believe it is now regularly used in mk's indy..
stephen_gusterson
posted on 17/9/03 at 09:52 PM Reply With Quote
mine came out of a volvo - dunno which type - poss a 240.
a visit to a scrappy will allow you to measure and select something to your needs. The polo seems popular tho.
atb
steve
Browser
posted on 17/9/03 at 10:20 PM Reply With Quote
I've seen a few Volvo 440's in the scrappy Steve and they have an admirably small radiator. I'll probably get meslf one of them when the time comes.
Stu16v
posted on 17/9/03 at 11:09 PM Reply With Quote
Simon, Westfields use the Polo rad in pretty much everything EXCEPT the V8 variants. The V8's use a custom built rad which was specially made for Westfield, and even these rads struggle to keep things cool. So unfortunately I doubt the Polo rad will be up to the job.
But if it will fit under your nose cone Vince, a Polo rad will be more than adequate....
VinceGledhill
posted on 18/9/03 at 02:23 PM Reply With Quote
Thanks guys. Looks like it's a polo then.... or the volvo depending upon what cars he has in and the looks of the rads when I get in there.
Regards
Vince Gledhill
