GaryM
| posted on 4/10/07 at 07:27 PM |
My new shiny trigger wheel
I've just received my new shiny laser cut 36-1 trigger wheel and i'm very pleased with it.
All I need now is to fabricate a bracket for my VR sensor and then I can have a go at getting my Megajolt working.
  Trigger Wheel
It's made from 5mm steel and is drilled to take a 7/16th bolt so I can bolt it onto the front of my xflow crankshaft pulley (with a spacer).
I ordered it from Martin Townsend who lists on eBay under teddy-edward1962.
It cost £10 inc P&P and only took a couple of days from order to delivery!
I have no association with Martin but would thoroughly recommend him and his work.
Gary
whitestu
| posted on 4/10/07 at 07:49 PM |
That looks good.
I made my own for my Zetec from a 1.8 CVH trigger wheel, welded onto the Zetec pulley.
The bracket for holding the pick up was a bit of a faff to make.
Yet to see if it works.
Stu
paulf
| posted on 4/10/07 at 08:40 PM |
Why did you need a trigger wheel for a zetec? most people use the one on the flywheel with the original vr sensor.
Paul.
quote: Originally posted by whitestu
That looks good.
Stu
bimbleuk
| posted on 5/10/07 at 08:55 AM |
Hmmm I recognise the workmanship as it looks like the timing wheel bundled with my ECU kit.
<<<< Could be the same Martin who machined up the timing bracket in my avatar. Spent a couple of hours in the workshop with him getting it
just right
[Edited on 5/10/07 by bimbleuk]
whitestu
| posted on 5/10/07 at 08:56 AM |
Hi Paul
Cos it cost less!
Seriously, I don't have a particularly good reason, other than I didn't get a flywheel with the Zetec I bought. I wasn't too
bothered as I got a 1.8 Focus engine with low miles for £60.
After checking around I realised the CVH flywheel would fit and is about 2.5Kg lighter than the 1.8 Zetec flywheel.
So no need to buy a flywheel / clutch as all the CVH bits can be used.
Fitting the trigger wheel from the CVH was pretty much cost free.
Stu
[Edited on 5/10/07 by whitestu]
| posted on 5/10/07 at 09:00 AM |
thanx for info. - that is really goodf price - beast the best I found up to know whcih I thik is £ 20.
| posted on 14/11/07 at 02:47 PM |
seconded - nice bit of kit, locost too (£ 10).
