Author: Subject: Properties of PTFE tape ?
givemethebighammer
posted on 28/9/03 at 08:48 AM Reply With Quote
I need to put some blanking plugs in my water system and in the engine block to remove redundant sender units. Question is will PTFE tape work to assist the seal ? Only ever used it on household plumbing systems.
thanks
posted on 28/9/03 at 08:53 AM Reply With Quote
It wil work on threaded holes as it is designed to but if the holes are clean and you are not thinking of removing the blanks too often you may be better using a thread seal compound and letting it set before putting any fluid or oil in.
yours, Pete.
givemethebighammer
posted on 28/9/03 at 08:08 PM Reply With Quote
so PTFE has no problems with temperature in an automotive environment then.
By thread sealant do you mean the blue threadlock stuff you would use on say flywheel bolts etc ?
[Edited on 28/9/03 by givemethebighammer]
stephen_gusterson
posted on 28/9/03 at 08:42 PM Reply With Quote
try using google to see the melting temp of ptfe....
atb
steve
posted on 28/9/03 at 09:01 PM Reply With Quote
I was thinking more along the lines of the liquid ones that set solid. I used one called Foliac jointing compound which was oil and heat resistant and looked like thick red oxide. Borrowed it from brother in law so I don't know where it came from.
Just googled it and came up with this.
http://www.lawson-his.co.uk/scripts/details.php?cat=Sealants&product=1047
Should be available elsewhere, sounds brilliant.
[Edited on 28/9/03 by Peteff]
paulf
posted on 28/9/03 at 09:30 PM Reply With Quote
paulf
posted on 28/9/03 at 09:33 PM Reply With Quote
Loctite do a very good pipe sealant in a tube that will work on hydraulics, steam gas and fuel lines. It is like a thread lock mixed with ptfe and is clean to use unlike Foliac and very effective. A tube has lasted me for the last 15 years and has not deteriorated.
Paul.
Big Stu
posted on 29/9/03 at 08:57 AM Reply With Quote
I have personally used PTFE tape on extremely high pressure systems (1850psi) with no problems. It should generally only be used for taper threads to assist the seal. I have never seen any problems with it from oil contamination or frost. So can't really see any problems with it.
Aaron
posted on 29/9/03 at 12:00 PM Reply With Quote
Yeah, I'll second that. We use it all the time on the coolant manifolds we make for our injection moulding tools at work. Never had a problem with temperature or anything else to my knowledge.
good luck,
Aaron
givemethebighammer
posted on 29/9/03 at 09:24 PM Reply With Quote
thanks
by the way they are taper threads
1/8 npt and 3/8 npt !!!!
took me long enough to find some blanking plugs for them !!!
