2b_pablo
| posted on 6/2/08 at 12:44 PM |
throttle cable and linkage (sierra pedal twin dhlas)
Hi guys, fitting my twin dellortos and my old throttle cable is goosed. Also the linkage I have isnt suitable for a number of reasons so I was looking
at linkage kits on ebay etc.
Will the throttle cables that come with the kit work well with the sierra pedal box or are they a waste of time? Was hoping Id get a
"free" cable by using the one (or pair) in the kit but suspect that because I use the sierra pedal box I might be stuck with a sierra
one.
Also can anyone recommend a good source for a dellorto twin linkage? Have my eye on this one:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=290204229018
Thanks guys
-paul
pajsh
| posted on 6/2/08 at 01:33 PM |
Just ordered one myself.
Try "fastroadcars" on ebay.
Much the same though.
I used to be apathetic but now I just don't care.
2b_pablo
| posted on 6/2/08 at 01:43 PM |
saw those ones, the one I posted just suits my setup a little better and there is only a quid or two difference
if it aint broke... pull it off and upgrade it!
| posted on 6/2/08 at 02:20 PM |
SIXTY QUID!!!! Call yourself a locoster???
You're not teling me that after welding up your chassis you incapapbel of bending a peice of steel to make a bracket for the cable, buy a couple
of springs, rod end and job done?
RS sell bearings if you want smoother operation and still be left with £ 50 in you pocket.
Here is one I made earlier. It may not be pretty to look at or be the ideal solution but so far it works and that is what matters.
  accelerator cable pulley
2b_pablo
| posted on 6/2/08 at 02:33 PM |
lol I couldnt weld to save my life!
I barely get enough time to get anything done on the car at the minute so its worth it for the time saved
Already 3 months overdue on this batch of "upgrades" and the first track day of the year is rapidly approaching.
worX
| posted on 6/2/08 at 03:02 PM |
You don't need to weld!
You could make the bracket above by plotting/bending and then riveting!
