Stuart_B
| posted on 26/3/08 at 09:02 PM |
Bike carb manifold
hi, here is my frist manifold i made, what do you think of it?
Stuart_B
| posted on 26/3/08 at 09:07 PM |
forgot the photo.
RichardK
| posted on 26/3/08 at 09:41 PM |
I would be concerned about the carbs sticking out too far, mine is just inside, and I mean just.
Have you got your inlet boots and carbs yet I presume you have as you have put the bends in the outer pipes, have you do this so to prevent re spacing
the carbs, have a dry run so you can see how far they will stick out.
2 penneth well deposited
Rich
Gallery updated 11/01/2011
Stuart_B
| posted on 27/3/08 at 08:23 AM |
Yes i ahve got the carbs, and the bends are there so i do not have to respace the carbs, and the carb end can be cut back. i will have a dry run with
them soon.
stuart
DarrenW
| posted on 27/3/08 at 09:35 AM |
My first manifold wasnt too far off that, i found what took the most work was fettling the internal bends so there were no sharp edges. I filled bad
internal rads with mixy ali stuff and then sanded by hand.
What are you using for joining tubes?
Stuart_B
| posted on 27/3/08 at 01:54 PM |
i got my tubes to join to the manifold. i use the rubbers which came with the carbs.
jacko
| posted on 27/3/08 at 06:18 PM |
Hi if you look in my photo archives there is a lot of photos of my manifold + engine photos with the carbs fitted it may help you
Jacko
Stuart_B
| posted on 27/3/08 at 06:43 PM |
How did you weld your manifold Together Jacko,Rich and DarrenW?
and rich what type of filters are they?
jacko
| posted on 27/3/08 at 07:17 PM |
Hi Stuart
in my photos you will see a jig i made. This bolts to a 5mm plate with holes to suit the head . then i made the pipes up but be fore welding them in
the jig i clamped it all to a big lump of channel to stop to bending .
[ i used a mig welder ]
after welding it all up i brazed the insides of the pipes on the bends the smooth the flow .
I hope this helps you
Graham
Stuart_B
| posted on 27/3/08 at 07:45 PM |
I used
these rods and it did not go as well as i throught.
DarrenW
| posted on 28/3/08 at 10:09 AM |
I cheated and used Boggs for mk2.
my filter is K&N challenger - rather large but doesnt run out of air.
