Staple balls
| posted on 3/12/03 at 11:57 AM |
pinto fuel plumbing diagrams?
has anyone got any info on where all the fuel lines and whatever need to go on a 1.6 pinto (with the bog standard weber carb)
cheers
alex
Staple balls
| posted on 3/12/03 at 10:45 PM |
blah
what goes where on this piccy? (things that need a home are circled)
clicky piccy
| posted on 3/12/03 at 11:18 PM |
right then, the thing at the front of the engine is (you probably know) the fuel pump. The bottom is a feed from the tank, the top goes to the filter
(left most hose) the spare tube in the *filter/swirl pot/ pressure regulator/whatever it is* is a return for excess fuel, goes back to the tank. HTH!
MK7
| posted on 3/12/03 at 11:40 PM |
Does mthis thread help?
http://www.locostbuilders.co.uk/viewthread.php?tid=4350&page=2
Russell
Staple balls
| posted on 4/12/03 at 03:26 AM |
cheers both.
i thought that was how it should go, but wnated to be sure
