The Baron
| posted on 13/8/08 at 04:46 PM |
Zetec Mondeo v's Escort
I am aware when i source my zetec engine that the escort one is better as it has a slightly different water pump configuration.
Question.
At my local scrappy, the engines have already been removed, how do I know the difference when looking at the basic engine?
cheers,
B
stevebubs
| posted on 13/8/08 at 05:28 PM |
escort water pump will have grooved ribs while mondeo water pump will be smooth.
stevebubs
| posted on 13/8/08 at 05:29 PM |
PS Only true for silvertops.
All blacktops have the same water pump irrespective of whether the engine is from a focus or mondeo ....
big_wasa
| posted on 13/8/08 at 05:43 PM |
better bet is the engine code.
1.8 Litre Engines (1796cc - Phase 1 & 2)
Code Standard Power Standard Torque Vehicle
RDA 105 PS @ 5500 153 Nm @ 4000 Escort 1.8
RKC 115 PS @ 5500 159 Nm @ 4500 Escort 1.8
RQB 130 PS @ 6250 162 Nm @ 4500 Escort 1.8
XR3i and GTi
RKA
RKB 112 PS @ 5750 158 Nm @ 3750 Mondeo 1.8
(To 05/98)
1.8 Litre Engines (1796cc - Phase 3)
RKF
RKH 115 PS @ 5750 159 Nm @ 4500 Mondeo 1.8
(05/98 On)
EYDA
To
EYDH 115 PS @ 5750 158 Nm @ 3750 Focus 1.8
2.0 Litre Engines (1988cc - Phase 1 & 2)
NGA 132 PS @ 6000 180 Nm @ 4000 Mondeo 2.0
(To 05/98)
2.0 Litre Engines (1989cc - Phase 3)
NGB
NGC 130 PS @ 6000 180 Nm @ 4000 Mondeo 2.0
(05/98 On)
EBBC
EBBD
EDBA
EDBB 125 PS @ 6000 180 Nm @ 4000 Cougar 2.0
EDDA
To
EDDG 135 PS @ 6000 180 Nm @ 4000 Focus 2.0
Werner Van Loock
| posted on 13/8/08 at 06:39 PM |
quote: Originally posted by robocog
Oil pumps stick out more on Mondeo's when compared to Escort/Fiesta items
Escort/Fiesta Left.....Mondeo on right
Regards
Rob
[Edited on 13/8/08 by robocog]
And the filter on the escort is not 90° angle to the block while mondeo is looking from the top that is.
But best bet is to look at the sump, as the escort sump is almost level and the mondeo sump is inclined so engine falls over when sitting on the
ground!
And then there's dipstick location, on mondeo it's in the middle of the rocker cover and on the escort it's on the timing belt end
And the flywheels if you can see them:
  Zetec flywheels
[Edited on 13/8/08 by Werner Van Loock]
http://www.clubstylus.be
bob
| posted on 13/8/08 at 06:46 PM |
Silver top escort water pump inlet pipe sticks straight out, mondeo 2 litre water pump inlet pipe leans back towards flywheel.
Talking flywheels, the mondeo 2 litre has a huge chunk of a flywheel where the escort has slightly less bulk.
As big wasa mentions the engine numbers/codes helps a lot. engine numbers are on flange flywheel end exhaust side near crank position sensor.
[Edited on 13/8/08 by bob]
The Baron
| posted on 13/8/08 at 08:15 PM |
Cheers All,
B
