steve m
| posted on 5/1/04 at 09:20 PM |
weber 40's problem
I am in the process of rebuilding my carbs
and having removed the butterflys, about a month ago
I can not remember, if the small hole on the butterfly goes at the top or bottom
can anyone help ????????????
regards
steve
Stu16v
| posted on 5/1/04 at 11:27 PM |
Steve, 'the hole' is probably something that a tuner as done to get the progression of the carbs somewhere near, as opposed to being
'standard' i.e. no holes IIRC.
I will endevour to look at a 'spare' I have floating around the garage tomorrow if I remember mate.
Stu16v
| posted on 7/1/04 at 07:03 PM |
Steve, I didnt remember, but I am going again in a few minutes....
Stu16v
| posted on 7/1/04 at 11:20 PM |
OK then, both sets of Webers didnt have holes, so I guess it is as I suspected, but nothing to worry about.
Is there any numbers stamped on the butterflys? When looking at the carbs on the 'engine' side, mine have 78deg stamped on them (refering
to the angle through which they travel). This number is readable from the engine side, stamped on the bottom side in relation to the spindle, and is
readable in the correct orientation in relation to the carb itself (i.e. the right way up!).
HTH Stu.
steve m
| posted on 8/1/04 at 01:47 AM |
Thanks Stu
Yes mine are stamped I think it Said 79%
but it could have been 78
Tomorrow I will stick them all together
thanks for your help
steve
