Dave Bailey
| posted on 12/10/08 at 08:03 PM |
Water Temp Sensor.
Hi!,
I have a DTA ECU and the water temp sensor ambient Res needs to be 2.4K but the Ford one I have is 33K. The problem is that the sensor I got with
the ECU is threaded and yet the Ford housing has a push in sensor. I would like to keep the thermostat housing so does anyone know if there is a 2.4K
sensor to fit this housing?
  Water Temp Sesor
big_wasa
| posted on 12/10/08 at 08:06 PM |
Just use the older zetec thermo housing from a silver top.
They screw in.
| posted on 12/10/08 at 08:12 PM |
I had a problem installing a coolant temperature sensor on my xflow. In the end I turned up a lump of ally to fit into the heater hose and screwed the
sensor into that. Works OK so could be a solution?
