Author: Subject: Timing???
Avoneer
posted on 13/1/04 at 03:38 PM Reply With Quote
Timing???
Does anyone have a rough idea what the timing should be set at for a
2ltr Pinto with a fast cam and twin 40's. My cam has proved to be
imposible to identify, so I was wondering if there is a norm. The
timing is currently set at 8 degrees BTDC.
Pat...
posted on 13/1/04 at 03:56 PM Reply With Quote
6 degrees.
That's the standard setting for a 2 litre running unleaded so you're not far out. If it runs o.k. I wouldn't worry about it. Most engines seem to rev freer when advanced a bit from the manufacturers settings so you might want to experiment, but I wouldn't be tempted to go too far.
yours, Pete.
[Edited on 13/1/04 by Peteff]
Stu16v
posted on 14/1/04 at 07:01 PM Reply With Quote
Have a read of this
The described method will get you in the ballpark, and take note of Dave Walkers comment too.
HTH Stu.
