paulf
| posted on 18/3/09 at 09:58 PM |
zzr 1400 engine
Ive been offered a very cheap zzr 1400 engine, I dont know full details yet but am told it includes clocks loom and ECU and there is a key card or
some type of transponder with it so im assuming everything needed to run it.
From what I can see they are near 200 bhp and dont need sump mods can anyone confirm this and comment on reliability for me?.
Paul
mangogrooveworkshop
| posted on 18/3/09 at 10:04 PM |
Shaft drive
Recently updated to meet the strict Euro-III emissions regulations, the ZZR1400 has also gained more power. With a maximum of 200hp, the mighty ZZR
also displays amazing low and mid range torque.
General information
Model: Kawasaki ZZR1400 ABS
Year: 2009
Category: Sport touring
Rating: 71.3 out of 100. Show full rating and compare with other bikes
Engine and transmission
Displacement: 1352.00 ccm (82.50 cubic inches)
Engine type: In-line four
Stroke: 4
Torque: 154.00 Nm (15.7 kgf-m or 113.6 ft.lbs) @ 7500 RPM
Compression: 10.7:1
Bore x stroke: 84.0 x 61.0 mm (3.3 x 2.4 inches)
Fuel system: Injection
Valves per cylinder: 4
Fuel control: DOHC
Ignition: TCBI with Digital Advance
Starter: Electric
Cooling system: Liquid
Gearbox: 6-speed
Transmission type
final drive: Shaft drive (cardan)
Clutch: Wet multi-disc, manual
More details Consult a Kawasaki repair manual.
Physical measures
Dry weight: 257.0 kg (566.6 pounds)
Seat height: 815 mm (32.1 inches) If adjustable, lowest setting.
Overall height: 1,170 mm (46.1 inches)
Overall length: 2,271 mm (89.4 inches)
Ground clearance: 125 mm (4.9 inches)
Wheelbase: 1,519 mm (59.8 inches)
Chassis and dimensions
Frame type: Monocoque, aluminium
Rake (fork angle): 26.1°
Trail: 112 mm (4.4 inches)
Front suspension: 43mm inverted, telescopic fork with adjustable rebound damping and spring preload / 4.4 in.
Rear suspension: Tetra-Lever with stepless rebound damping adjustment and remote spring preload adjuster / 5.4 in.
Front tyre dimensions: 120/70-ZR17
Rear tyre dimensions: 190/50-ZR17
Front brakes: Double disc. ABS
Front brakes diameter: 310 mm (12.2 inches)
Rear brakes: Single disc. ABS
Rear brakes diameter: 270 mm (10.6 inches)
Speed and acceleration
Other specifications
Fuel capacity: 21.95 litres (5.80 gallons)
Color options: Black, green
Comments: 149.5 KW with Ram air
Further information
Parts and accessories Check out parts and accessories from our partners. Kawasaki ZZR1400 ABS accessories
Ask questions Join the 09 Kawasaki ZZR1400 ABS discussion group,
the new Kawasaki forum at Bikez.name or
twybrow
| posted on 18/3/09 at 10:14 PM |
Useless engine - pass the details of your contact to me, and I'll be happy to dispose of it for him!
yorkshire-engines
| posted on 18/3/09 at 10:16 PM |
be carefull there are at least 17 stolen engines on this weeks watch list
zzr1400 engines with keys are not cheep
let me have engine number and ill check it out for you
ZXT40AE----------
cheer s malc
| posted on 18/3/09 at 11:13 PM |
If you need to hide it - I know a perfect place for it... but I have (mild temporary) alzheimers so may not remember where I put it.
dean100yz
| posted on 19/3/09 at 08:27 AM |
lol I was thinking the same thing...
Makes some serious torque! Kwak engines always seem good in power and make a great sound!
paulf
| posted on 19/3/09 at 08:35 PM |
If it turns out to be available at the price I have been quoted and is legit then it will most likely be finding a home in my car. I have a blade
engine but never fitted that as I prefered the tourque and driveability of a zetec but think this would be worth fitting.
Paul
paulf
| posted on 27/3/09 at 10:20 PM |
Just found out a bit more , its a gtr1400 which seems to be a detuned zzr with more torque but only 155hp but high ratio 6th gear , full set of
clocks Ecu and loom .Im going to look at it tommorow to find out more.
Paul
