pekwah1
| posted on 5/12/11 at 05:04 PM |
All in one rear lights
Hi Guys,
If i bought a couple of these, would i be able to turn one of the reverse lights into a fog light instead with a red bulb?
It needs to be able to pass an IVA...
http://www.cbsonline.co.uk/product/All_In_One_Rear_Light_RLT1
blakep82
| posted on 5/12/11 at 05:09 PM |
fog light lens has to be marked with an F so, i imagine it won't be possible, as they'd have made it with reverse in mind... but check the
lens
________________________
steve m
| posted on 5/12/11 at 05:11 PM |
Andy,
you can borrow my proper fog light, for the IVA, as i will only have it fitted for the mot in may
bigdrew
| posted on 5/12/11 at 05:12 PM |
I'd guess at no because the fog needs to have a specific lens pattern which I can't imagen that reverse bit has.
People have failed with 'fog lights' that they had bought due to the lens..
Could be wrong though!
pekwah1
| posted on 5/12/11 at 05:17 PM |
Hmm thought that might be the case, thanks guys!
Steve, thanks for the offer but i guess i should probably have a fog light, need a reverse light as well so might as well get a matching pair!
steve m
| posted on 5/12/11 at 05:19 PM |
Is a reverse light mandatry for IVA?
My fog light is still available, if you need it,
pekwah1
| posted on 5/12/11 at 05:21 PM |
yes i believe that it is considered useful that people can tell that you're reversing....!
good one steve!
steve m
| posted on 5/12/11 at 05:27 PM |
A reverse light is not required on my car,
as they can hear me getting closer !!
wylliezx9r
| posted on 5/12/11 at 05:28 PM |
A reverse light is also mandatory.
George Best
blakep82
yep, reverse now mandatory for IVA (wasn't for SVA though)
think it still isn't needed for MOT though...
i like these ones
http://www.ledautolamps-uk.com/productshow.php?catid=4&productid=23
the one with part number 135FMGE
BobM
| posted on 5/12/11 at 06:21 PM |
quote: Originally posted by pekwah1
Hi Guys,
Even if you can you'll fail. You need minimum separation of 100mm between rear fog and brake lights
[Edited on 5/12/11 by BobM]
Not very Locost but very BEC
RK
| posted on 5/12/11 at 09:25 PM |
Can't you just mount a fog light under the rear panel, as some Caterhams do? They swivel, so you can get the required IVA correct angle. No need
to pierce your back panel.
