Author: Subject: Oil Pressure Sender Zetec block thread
Hammy360
posted on 12/10/16 at 05:06 PM Reply With Quote
Hi anyone know what thread the torx screw plug is in the 2.0 blacktop zetec block? I want to put to put my OPS in there, its about 6 inches to the left of the Ford Oil light sensor. I need to order an adaptor for my sender which is 1/8th NPT
Cheers Guys
Hammy
Hammy
big_wasa
posted on 12/10/16 at 06:33 PM Reply With Quote
It's 1/4 npt the same as the oil pressure switch. Ford used it to feed the the turbo on the focus Rs.
[Edited on 12/10/16 by big_wasa]
Hammy360
posted on 12/10/16 at 06:42 PM Reply With Quote
Cheers Warren, Ill get on and order a 1/8th to 1/4 adaptor
Hammy
tims31
posted on 24/10/16 at 03:22 PM Reply With Quote
Is it ok to use this point on the Zetec block? I've just got my pressure sender through (1/8 NPT too) and was looking at having to buy an extension or t-piece adapter to replace the switch but if I can use the drilling next to it that would make things easier.
Just need to get an adapter then
[Edited on 24/10/16 by tims31]
Build: http://www.martinsfurybuild.co.uk/
Matth93
posted on 24/10/16 at 06:09 PM Reply With Quote
I have just used it on my car and it's fine just got a adapter for the thread
Hammy360
posted on 25/10/16 at 12:08 PM Reply With Quote
Its totally OKmate
Hammy
tims31
posted on 26/10/16 at 08:07 PM Reply With Quote
Excellent, easier position to fit too, any ideas of the best place to get an adapter?
