Author: Subject: Lighting Suppliers
Nick Davison
posted on 19/5/03 at 09:08 AM Reply With Quote
Lighting Suppliers
Has anyone a contact for lighting supplies. Ideally I would like to fit square headlights like the Dax, the smaller the better.
Nick
MK9R
posted on 19/5/03 at 09:52 AM Reply With Quote
Clickety click this-
stafford
Lighting components
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
stephen_gusterson
posted on 19/5/03 at 11:50 AM Reply With Quote
searc on line also for
europa spares
and
vehicle wiring products
jonti
posted on 19/5/03 at 01:39 PM Reply With Quote
Nice one Austen
They look right good..prices are ok and they're jsut down the road
J.J
[Edited on 19/5/03 by jonti]
OFROK
Nick Davison
posted on 20/5/03 at 07:17 PM Reply With Quote
Is there a minimum size for the diameter of head lights, for SVA and what position do they have to be on the car, height , distance from the front etc?
Nick
stephen_gusterson
posted on 20/5/03 at 09:17 PM Reply With Quote
http://groups.yahoo.com/group/svaonline
join and you get sent a copy of sva
wade thro the crap at the front .....the real bits are at the latter part
atb
steve
Dave_the_sparks
posted on 21/5/03 at 05:11 PM Reply With Quote
Thanx for the SVA tip Steve, will come in very handy!
Dave.
mobile auto-electrical specialists www.hammondauto.co.uk
MK9R
posted on 22/5/03 at 06:47 AM Reply With Quote
If you use a Dax style bumper to mount your indicators and side lights, you can mount the headlights a lot lower. It also means that your front suspension will not be classed as the front of your vehicle for sva, so you won't have to wrap everything if foam. Apparently the bumper falls off afetr sva?
click for picture
[Edited on 22/5/03 by MK9R]
Cheers Austen
RGB car number 9
www.trackace.co.uk
posted on 23/5/03 at 08:22 AM Reply With Quote
A word of caution about the SVC headlights - the nice (expensive) chrome ones.
I bought some at the show, and when I tried to fit them the mounting bolt turned in the shell. Fair enough, I thought, I hadn't located it properly before I started. Stripped it down, and found that the little tab that's meant to stop it rotating was twisted up. Put it straight with no trouble at all, 'cos it was just a bit of thin mild steel. Lined it all up, tried to tighten the bolt, and it just twisted again.
Rang SVC, who said that the tab should be spring steel, and asked me to send them back. Did that, and eventually got a call from someone who said that there's nothing wrong with them. The conversation went as follows:
SVC: "There's nothing wrong - I tightened the nut up with my fingers and everything stays OK"
Me: "It's OK until you tighten it with a spanner - which you have to do, so that it stays pointing in the right direction"
SVC: "But if I tighten it with a spanner I might damage the chrome plating"
Me: "Then you're never going to see the problem!"
[repeat this conversation several times with minor variations until SVC man gets the idea]
He finally agrees to refund my money (but that was 3 days ago, and the refund hasn't hit my bank account yet )
[just checked - the money's in my account, at last!]
The moral is: "just because it's expensive, doesn't mean it's good!"
Now I've got to look around for some more headlights!
DJ
[Edited on 23/5/03 by David Jenkins]
Mark Allanson
posted on 23/5/03 at 07:27 PM Reply With Quote
Try here, I found the service really good
Nick Davison
posted on 25/5/03 at 11:34 AM Reply With Quote
Syd
Just what I needed, thanks.
Nick
SteveO
posted on 28/5/03 at 10:01 PM Reply With Quote
Like Nick D, like the look of square headlamps without coughing-up £150.00. i have found some Yamaha bike lights that can use 12v car bulbs thats nice, does anyone know if the SVA man has anything against bike headlights on a seven???
