Im having problems with oil breathing on a Zetec Turbo engine we built last year, I know there are a couple of lads on here that have Zetec Turbo
engines in their Kit cars.
I was wondering how these guys have set up their oil breather systyem.
I have got a pipe that goes from the sump upto and into the cam cover and then I have another pipe from cam cover into oil catch tank.
The problem I think I have got is that there is to much pressure coming up the pipe into the Cam cover which is forcing oil out under the seal.
Does anybody have any suggestions how I could overcome this problem.
My Nephews car has the exact same problem
Pictures in my gallery below on how I've done mine, not done many miles with this set up but first impressions are good.
Haven't got a turbo though if that makes any difference.
Rich
[Edited on 15/2/11 by RichardK]
Dont you need to have an oil separator to prevent the oil going into the cam cover? It could be that the crankcase pressure is pressurising the cam
cover, and forcing the oil out of the seal anyway?
Either way, i think i would put a separator in, and have both the cam cover (which should breathe out, not in) and the crankcase breather into a catch
tank. That would need a breather, but will also catch any oil vapour.
(Assuming you mean crankcase, not Sump)
If the hose is at the sump, then id be alarmed that you may either be syphoning oil into the top of the engine, or even airating your oil from the
breather.
[Edited on 15-2-11 by MakeEverything]
The pipe out of the sump is positioned above the oil level to allow crankcase compression to escape. I think it may need an oil seperator in the line.
When I had this pipe straight into oil catch tank it was filling tank up, thats why I put it into cam cover so oil could return to the sump. Do you
not think this is right.
Thanks Paul
Originally posted by zetechamo
The pipe out of the sump is positioned above the oil level to allow crankcase compression to escape. I think it may need an oil seperator in the line. When I had this pipe straight into oil catch tank it was filling tank up, thats why I put it into cam cover so oil could return to the sump. Do you not think this is right.
Thanks Paul
Just a quick thought, as a non-zetec person but owning a turbocharged motor and a few others...
Cam cover vents are designed to be either atmospheric or vacuum (positive ventillation). All the cam cover vents I've seen have either been fed
through a catch can to remove residue and vented back to pre-turbo intake, or simply atmospherically vented.
I know for a fact that atmos venting of my cam cover on the 3sgte leads to excess oil usage/burning which ive not thought about further. I'd
suggest that your cam needs to be re-routed to the intake (or atmos through a filter) and the crankcase/sump tube needs to be blocked or used with a
catch can as a return for the oil residue. Or link the two together but vent them both to the intake. Either way I don't think it's meant to
be connected together as the crankcase and cam cover voids are internally linked - all you're doing is blocking all ventilation.
[Edited on 15/2/11 by coyoteboy]
Just to add the breather system on the sr20det engine is a pipe from the engine block to cam cover on one side then cam cover to turbo inlet pipe with
pcv
But i have done away with the feed back into the turbo inlet pipe and will be going to a catch tank i must add that no oil comes out
I beleive the problem that you have with that set up is the sump part of the breather i know its tight where the turbo is but it really need to at the
original breather point on the engine block
On my Zetec Turbo I have drilled 2 x 17mm breather holes through the block just above the sump line (one on each side of the block), and vented both
of these independantly to a catch tank. The cam cover is also vented to the same catch tank.
The original breather hole in the block (behind the exhaust manifold) is blocked off with an ally plate (can't fit a breather there as the turbo
gets in the way).
I've been running approx 1 bar on a TD04 turbo, and it seems to have worked fine for a few thousand miles of brutal thrashing and 4 or 5 track
days - the catch tank barely gets a dribble in it.
Hope this helps!
Tom
