Does any1 know if gts does a rollbar, but a nice one, chrome if possible? Ta
pics wud b nice
Hi,
Yes we sell rollbars (nice ones at that!) and you could chrome them if you so wish. In fact, if you have a particular design in mind that you fancy we
will bend it for you special for no extra cost!
Kind regards,
Darren
Darren@gtstuning.co.uk
I bet thats opened the flood gates for a whole host of crazy shaped roll bars..or at least requests.
I dread to imagine....
Mark
Thts amazin! I know where i'll be gettin mine from
. How much is it for a nice chrome one approx. Darren? And also how much is the rear
panel? Cheers
Prices....
Hi darren could you give me an idea of the price for a FIA roll bar, with and without slight inward taper, rear stays to the sides not top of the
bar...... and ..... the stays attached like the westfield FIA bar!
I made a slight mistake and my 4" square plates aren't a 100% level (taper backwards slightly) so if i could attach the rear stays via a
rose joint it would allow me to adjust things as necessary.
Also could you or someone else tell me how high the bar is from the top chassis rail.
Mike
Would you get away with having rose joints on the rear stays ??? Wouldn't it be easier just to correct the mistake
Correct my mistake .... how dare you
I've fully welded everthing and its only a small difference....
As for rose joints - westfield do! I sort of assume that if its okay for their FIA roll bar then it should be ok in general! Obviously you need to get
beefy rose joints.
The other option is i weld in the stays myself..... just couldn't be bothered with all the faff of filing, checking ,filing, checking .... ah,
weld.
(although darren, go on, if you're going to be nice and msg me a price for the other stuff
Rosejoints are OK
