Does anyone supply 25x25x1.5 squares for closing the ends of tubes?
alistairolsen - 14/12/09 at 03:49 PM
Someone must to packs of these punched or laser cut or something?
Steve G - 14/12/09 at 03:51 PM
ebay for plastic caps
Not sure i'd want to weld the ends up myself. Open ends mean you can get a waxoyl lance in there for starters
[Edited on 14/12/09 by Steve G]
tomprescott - 14/12/09 at 03:52 PM
Think you can get them from tifosi too!
alistairolsen - 14/12/09 at 03:54 PM
No, I meant metal sheet to weld over the open ends?
Confused but excited. - 14/12/09 at 03:55 PM
He's not looking for plastic plugs, he want 1,5mm thick mild steel squares.
Bugger! Must type faster.
[Edited on 14/12/09 by Confused but excited.]
RAYLEE29 - 14/12/09 at 03:58 PM
Just cut mine from offcuts of box section
its what most fabricators do
Ray
p.s cut to fit inside weld in grind off
Ivan - 14/12/09 at 04:18 PM
Buy a strip of 25 X 1.5 or even 1 mm roughly the length you need to cover all + 15% and with shears cut off pieces slightly longer than 25 mm , weld on 3 sides and grind 4th side flush with angry grinder then weld - easy peasy.
MikeRJ - 14/12/09 at 05:42 PM
I cut the lengths 25mm longer than needed, chop out 3 of the sides for a length of 25mm at the end, fold the remaining tab over and weld the three edges.
If that's confusing, it's more difficult to describe than to do it
maartenromijn - 14/12/09 at 06:06 PM
I have cut a strip from leftovers of my steel floorplate.
alistairolsen - 15/12/09 at 08:28 AM
Massive thanks to andyw7de for offering to cut some for me! Above and beyond!
